need help!!! installing alarm....
Old May 10, 2001 | 05:45 PM
Slickismax's Avatar
where is the ignition wire? I am hooking up the starter kill, and I need to know which wire to cut. Please help asap!
Old May 10, 2001 | 06:46 PM
MaineI30's Avatar
info
Ignition in yours SHOULD BE blk/white or blk/red at the ignition harness... but please check. Starter is different tho I think... blk/yellow or blk/white at the ignition harness.
There is a second start wire (grn/blk or red/blu) that needs power if you are doing a remote start.
Old May 10, 2001 | 09:16 PM
Matt93SE's Avatar
STFU n00b!
Heeeeey bill. whassup man?
here's some stuff you might want, if you haven't figured it out already.
http://www.ee.utulsa.edu/~mblehm/faq/dei%201995.gif
http://www.ee.utulsa.edu/~mblehm/faq/mt%201995-97.gif
Good luck with that install.
Old May 11, 2001 | 10:47 AM
yongjun's Avatar
Hey Bill!
When you coming back to Dallas?
I'm home now for the summer.
Give me a call sometime.
Old May 11, 2001 | 01:35 PM
Chunger's Avatar
My other car is a Hybrid
Same as Matt's link above:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|wht/red or wht/pur |+ |ignition harness |
| STARTER|blk/yel or blk/wht |+ |ignition harness |
| SECOND STARTER|grn/blk or red/blu |+ |ignition harness |
| IGNITION|blk/wht or blk/red |+ |ignition harness |
| SECOND IGNITION|red/yel or red |+ |ignition harness |
| ACCESSORY|blue or wht/blk |+ |ignition harness |
| POWER LOCK|lt. green/red |- |in drivers door at switch |
| POWER UNLOCK|green/yellow *1 |- |in drivers door at switch |
| LOCK MOTOR|brown/white | |in drivers door at switch |
| UNLOCK MOTOR|brown | |in drivers door at switch |
| DISARM DEFEAT|brown | |in passenger door at switch |
| PARKING LIGHTS +|red/green | |steering column |
| HEADLIGHTS|gry/yel(L)blu/blk(R)|+ |steering column |
| DOOR TRIGGER|red/white |- |low in drivers kick |
| TRUNK/HATCH PIN|purple/yellow |- |drivers kick or BCM *2 |
| HOOD PIN|yellow/black |- |BCM *2 |
|TRNK/HTCH RELEASE|purple/yellow |- |low drivers kick *3 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| DISARM NO UNLOCK|*4 | | |
| TACHOMETER|white/green | |ECM *5 |
| BRAKE WIRE|red/green |+ |at brake switch |
| HORN TRIGGER|green/white |- | |
| WIPERS|lt. green/red |- |steering column |
| LF WINDOW UP/DN|blu/red - blu/blk |A |in LF door at switch |
| RF WINDOW UP/DN|blu/red - blu/blk |A |in RF door at switch |
| LR WINDOW UP/DN|blu/red - blu/blk |A |in LR door at switch |
| RR WINDOW UP/DN|blu/red - blu/blk |A |in RR door at switch |
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
