WTF: in neutral and RPMs bounce off rev limiter
Old Apr 22, 2005 | 02:43 PM
ja1997max's Avatar
Accelerated in first gear to get across traffic, shift to 2nd and then the RPM's just started bouncing off the rev limiter with the engine roaring. I shifted to neutral and it contiuned about four times bouncing off the rev limiter without my foot anywhere near the gas...WTF...it then finally stopped....then it happened again 5 minutes later, similar scenario.
I just had a brand new clutch and rebuilt trans today. Anyone else with this experience or know what the problem is. The transmission shop is closed for the weekend so no way to get a hold of them.
Thanks for any help.
Old Apr 22, 2005 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
Check your throttle cable.
Old Apr 22, 2005 | 04:21 PM
KsuMax's Avatar
Cheesing away...
sounds like your throttle is sticking. Make sure the cable isn't catching on anything.
Old Apr 22, 2005 | 05:11 PM
maximazation's Avatar
the deposits on the sleeve of the throttle cable might make the cable stick, try inspecting it and clean if there is build up
Old Apr 22, 2005 | 05:32 PM
ja1997max's Avatar
Thanks for the suggestions...makes sense. I'll check it tommorow.
Old Apr 22, 2005 | 08:00 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
just after i had my tranny replaced, this happened to me. when i shop put my intake back on, they put the straps on backwards and the throttle cable was sticking on one of them.
Old Apr 22, 2005 | 08:54 PM
nadir_s's Avatar
vicodin ... gift of life
damn that's dangerous, yeah definately sounds like a sticky throttle cable.
Old Apr 23, 2005 | 10:11 AM
ja1997max's Avatar
This is exactly what my problem was. This is a good thing for everyone to keep in mind and should make sure to check anytime they get work done or do it themselves b/c it really could have turned into a dangerous situation, I was just fortunate.
THanks for the help everyone, you guys were right on!
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
