Holy Hotspots Batman, crappy LEDs
Old May 10, 2005 | 06:58 PM
Kevlo911's Avatar
Kevlo for President
I bought 194 WHITE Oval Wide Angle Lenses LEDs from:
http://autolumination.com/194.htm
And they freaking suck. I figured wide angle leds would shine a wide beam but apparently not
It was a huge waste of money and know I need to buy some new 194 LEDs, which ones should I get?
Old May 10, 2005 | 07:15 PM
Chief Brody's Avatar
Wow, that's bad. I got the cheap ones from www.superbrightleds.com. Mine are blue and are very even but wish they were a bit brighter. They are about stock brightness. I was thinking of trying the white leds. More of a stock look, I kind of miss it. Anyway they are less than a buck each I think.
I think the ones with multiple leds, while brighter, are more prone to hotspots.
Old May 10, 2005 | 07:34 PM
AscendantMax's Avatar
i bought some red wide angle leds from superbrightleds...they were too freaking dim. so i just some 'xenon' red ones in there.
Old May 10, 2005 | 11:16 PM
nyautostyle's Avatar
wow you cant see anything on those. how u tried to exchange them for something else?
Old May 11, 2005 | 12:43 AM
05MaXiMaMenG's Avatar
autolumination.com sux big elephant *********!!!
Old May 11, 2005 | 12:50 AM
Kazao's Avatar
yeah that does suck.
Old May 11, 2005 | 04:27 AM
X-Vert's Avatar
30-40mph for road
100mph for highway
All you need to see
Old May 11, 2005 | 05:39 AM
MainSource's Avatar
Hit 'em with the stun gun
Attack of the Crap! Ruuun! Quickly replace those with ones from superbrightleds pleez.
Old May 11, 2005 | 11:07 AM
Kevlo911's Avatar
Kevlo for President
The LEDs have been in my room for a few months now, I never installed them because I need hte clips that hold the black guage peice around the cluster in.
Should I get these from www.superbrightleds.com?:
These 12 Volt Super Bright LED bulbs will replace T3-1/4 (#194/168) filament bulbs found in many automobile and water craft applications. Inverted cone clear lens causes the light to emit from the sides as well as the end.
Or which one should I get? http://www.superbrightleds.com/1157.htm
I want the entire guage cluster to be bright and lit w/ minimum amount of hot spots.
Old May 11, 2005 | 11:13 AM
Akumachan's Avatar
I never narc'd on nobody.
why dont you take them out and sand them, so theyll spread light better? not that leds are expensive, but whats the point of buying something you already have?
Old May 11, 2005 | 11:27 AM
Kevlo911's Avatar
Kevlo for President
I don't think sanding them will make the light spread out better.
It looks like that, there is not much to sand.
Old May 11, 2005 | 11:38 AM
JPMax's Avatar
What's next!?..
sand the top dome area of the bulbs and see if it's any better.
Old May 11, 2005 | 11:58 AM
Wisdoms97's Avatar
yeah you guys are right. i bought the red 4 LED wedges from superbrightleds and sanded down those nubs on the ends. defintely evened things out a bit. not PERFECT but close.
Old May 11, 2005 | 01:50 PM
Kevlo911's Avatar
Kevlo for President
Those are inverted LEDs, I am going to buy those, no hot spots. I will put 2 of my leds in the doors and other 3 in various places around the car
Old May 11, 2005 | 03:51 PM
e r y k's Avatar
Kevlo911, can you please link me to those inverted LEDS
Old May 11, 2005 | 03:55 PM
Kevlo911's Avatar
Kevlo for President
Scroll down on that page and you will see them.
Old May 15, 2005 | 10:32 AM
Maxtank's Avatar
98-99 guys, do not get the #74 bulbs! They are horrible....convert to 194 or use a custom LED setup
Old May 15, 2005 | 12:55 PM
MDeezy's Avatar
thank you I will post pics but I bought some 6 LED from superbright and I have hot spots, its not as bad, but still not satisfying enough.
Post pics guy when you get them installed.
edit: is it just me or am I only seeing wide leds and polarized etc. but nothing actually saying inverterted?
Old May 15, 2005 | 07:32 PM
RoRLegion's Avatar
Thanks for posting that Kevlo911. I'm going to get those.
Old May 15, 2005 | 10:32 PM
1FSTMAX's Avatar
i used these LED's and it gives a very even light distribution inside the gauge cluster.
Old May 16, 2005 | 03:56 AM
ny96max's Avatar
if you want even fill on your gauges buy the 194 bulbs from www.superbrightleds.com get the ones that have 6mini led's on them, they are the largest and brightest you can fit into a 95-96 housing.
Ant
Old May 16, 2005 | 12:14 PM
Kevlo911's Avatar
Kevlo for President
Ant
95-97 Housing
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
