How does a hoodscoop work when raining?
Ok well, since we are on the topic, I was wondering the same thing, but on a different vehicle. On the Evo 8, the hoodscoop is flat on the hood, and water can easily get into the engine, correct? And upon quick inspection, the alternator didn't seem like it was really protected from the water, now I'm not sure of waterproof alternators, but I always thought it was risky business getting your alternator wet, but how do they avoid this on the Evo??
waters healthy for the engine, sometime the motor gets thirsty
i wouldnt really worry about the rain too much, my boy has a fiberglass one on his corrollas hood, and he has side draft carbs with no filters on it and he hasnt had a problem. especially your cold air so its not like the scoop is by the intake. i think it would be a problem if buckets of water start comming through the hood, either than that you shouldnt worry, most aftermarket filters withstand small amount of water too.
u first said the air filter from the cai is in the fender, how does this hood scoop even become functional, its then not getting any cold air to the intake really. or are you talkin pop charger where the scoop directs the air to the filter?
either way, i dont think manufacturers forgot about this idea when designing a hood scoop for a car. u should be ok
Hood scoops aren't effective or functional until you exceed 100mph anyway. That particular scoop is so small that a minimal amount of water would be sucked in and even then would be dissapated by the air filter.
I don't see how a hood scoop is any different than any other opening you have in the front of you car. If anything, your grill will probably let more water into your engine compartment, especially if you are driving down the highway in the rain. My 2 cents.
Originally Posted by Chris91SE
cool...i'll go right ahead and put a plain hood my wrx now...
Anyway, I guess you've never heard of a car company doing something more for looks than function.
the stock hoodscoop on imprezas, or evo's isnt even made for a "ram air effect". its obviously just to keep the engine/turbo a bit cooler, by letting more air in...no one has even mentioned ram air, its a completely different thing! saying all hood scoops are pointless unless your going over 100 is ridiculous
I'm not knocking Evo, Impreza or WRX hood scoops or their owners. I like those cars' performance, very impressive. But, one has to wonder if scoops work so well for cooling or whatever, why don't more car car companies use them?
Like I said before, I'm just passing on what I read in Car & Driver.
Originally Posted by SDot82
Correct me if I am wrong, but the hoodscoop on the wrx and sti's are for their intercoolers (since they are place ontop of the engine) and not to keep there engine/turbo cooler.
and for the others.....all the water that comes from the rain through the hoodscoop is directed to a safe place where the motor will not be damaged by the water.
It will be pointless for us to have one since the hoodscoop is so small, i doubt it'll make any difference.
Ok. So that huge F-ing monster of a hood scoop on the front of an STI is not just for looks. Its actually allowing cool air from outside the engine compartment to flow to the intercooler, which cools the air running through the turbo to the engine? So, what's the effect of the hoodscoop in HP?
If the 300 hp STI/WRX/Evo gains less than 3 HP from the scoop then I agree with Bladerunr when he says that all hood scoops are just for looks. If the STI/WRX/EVO gains 10 HP from the scoop then Bladerunr is wrong; hoodscoops are not "for wimps."
Matt93SE
04-08-2018 09:23 AM
jerrod99_se-l
08-27-2015 08:27 PM
