replacing brake lines
Old Sep 26, 2005 | 08:22 AM
ColdSHO's Avatar
in an attempt to put on my new ss brake lines i ran into a roblem, i cant break the olds ones loose i beieve its a 10mm nut i have to spin but its not doing anything but twisting. i cant get it to break loose, how did u guys get urs free?
Old Sep 26, 2005 | 11:17 AM
Dubbya's Avatar
VK56 Inside
Try some PB Blaster
Old Sep 26, 2005 | 12:33 PM
ColdSHO's Avatar
i tried that, i got a new can just for this project, still nothing
Old Sep 29, 2005 | 11:25 AM
Lordrandall's Avatar
Are you using a regular open ended wrench, or a flare wrench?
Old Sep 29, 2005 | 02:18 PM
ColdSHO's Avatar
standard open ended
Old Sep 29, 2005 | 02:47 PM
njmaxseltd's Avatar
Originally Posted by ColdSHO
standard open ended
Thats the reason why.
You need to use the correct tool for this job.
Old Sep 29, 2005 | 04:54 PM
A Flood99's Avatar
flare nut wrench
and try and turn the stock brake line(rubber) and NOT the metal hard line
its much easier to strip the bolt on the hard line than the bolt on the rubber lines
Old Sep 29, 2005 | 05:01 PM
vsamoylov
be carefull or you will do what i did and strip the nut on teh hardline. now i have to go order a new hardline.
Old Sep 29, 2005 | 07:57 PM
killerVQ30DE's Avatar
Originally Posted by A Flood99
flare nut wrench
Dam another deal i need to buy, I assume you can't fit a 10mm 1/4 socket drive in there?
Old Sep 30, 2005 | 12:32 PM
Ummm, not so much.
Old Sep 30, 2005 | 01:26 PM
Matt93SE's Avatar
STFU n00b!
not unless you cut the end of the hard line off.
just buy the 10mm flare nut wrench. they're like $5 at Sears.
I have a 17mm one for oxygen sensors too. it's saved my **** a couple times on customer cars.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
