Very Important "Discovery" re Strut Bars
Old Oct 7, 2005 | 02:44 PM
  #81
RA030726's Avatar
I'm nutty for Nissans
i showed pix of 240sx fender bars and 240sx subframe spacers/collars.
http://www.nissanperformancemag.com/february04/240sx/
http://www.nissanperformancemag.com/june04/240sx/
the spacers are metal and eliminate flex. we could use these up front, at least i think so. fender bars stiffen up the weakest part of the chassis, where the fire wall is.
Old Apr 19, 2006 | 08:42 PM
  #82
VQuick's Avatar
Chassis Freak
Does anyone know if the Cattman FSTB (or any other FSTB) is solid, one-piece construction? I am interested in getting a non-hinged FSTB, preferably made out of steel. I'm convinced that the two hinge points in cheap FSTB's allow a lot more flex than most people think. There's no way that two small bolts are going to prevent flex in the FSTB (or movement about the hinges) given the continual forces in all directions from the entire weight of the front end going around corners.
I'm also bumping this thread in case any other people want to go against the Org orthodoxy and try this, and post their impressions here. Please no
Old Apr 20, 2006 | 10:28 AM
  #83
bigEL's Avatar
Looks like it is one piece non-adjustable, but easiest way to find out is just inquire directly. I also have my doubts about how stable those cheap adjustable bars are, but a lot of people seem to have good results with them. The Paradox bar on the other hand, just looks wicked. http://www.paradox-systems.com/produ...products_id=85
Old Apr 21, 2006 | 08:01 AM
  #84
DrKlop's Avatar
Driving is the next best thing
I don't think it would make much or a difference unless you were to weld the brackets to the body. Having a solid bar also makes it harder to take it off in case you need to get to something under it, like rear coils.
BTW: why not just weld the regular bar to its brackets?
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
