oil
Old Oct 11, 2000 | 08:27 PM
sleeper's Avatar
just a note on oil. 5w -30 is for all temps., 10w -30 is for above 0 degrees. for 4th gens. s/c er internal is sprayed with oil and then oil is drained back into the engine. vortech recommends staying at normal engine fill capacities, and using recommended oil viscosities. although i would think that using a tad bit more oil to compensate for the oil in the line to s/c would be reasonable.any comments.?
Old Oct 12, 2000 | 07:03 AM
humaras's Avatar
4th gener
THe capacity for the 4 generation Max is 4 1/4 quart according to the owners manual...but i usually see them put about 5 quarts in usally when they do a oil change--is that bad when they refill it too much?
Old Oct 12, 2000 | 07:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: 4th gener
yes it's bad. the cranks splashes too much of the oil and it robs some hps and i think* it adds air in the oil itself...like beating a egg. if it's slightly overfilled it think you'll be safe...but more than a qt i would drain some out so it's closer to spec.
Dan
Old Oct 12, 2000 | 08:41 AM
DavidL7's Avatar
I always use 5W-30 year round and just recently changed to Amsoil.
When you drain your oil do you get 4 quarts or do you get more? When I change my oil I put in 4.5 quarts but usually only about 4 quarts comes out.
Old Oct 12, 2000 | 08:45 AM
Jeff92se's Avatar
I'm needing a caw
It can be bad-->
If the crank foams up the oil, it puts air into the oil and can create lubrication problems obviously. So yes, too much oil can be a bad thing.
Old Oct 12, 2000 | 09:07 AM
humaras's Avatar
traditional change
I usually take it to this mechanic that jacks up my car, lets the oil drain out --and it takes a good 10 minutes or so for all of the crap to drain out. THen he plugs it back up and puts the new oil in. There was this one time I got some aftermarket engine flush and I put it in and asked him to run it...and more disgusting oily gunk came out and then he refilled with new oil.
I never see how much oil comes out--and obviosly it is nearly impossible to get every drop of it since there are some in the filter too. Whne he takes the filter out before the refill, I see more oil...and I assume more or less, everything has been drained out--as much as possible. I will watch out though in the future and first put 4 quarts in and then the rest...I will slowly add.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
