Push Start
Old Nov 27, 2005 | 01:52 PM
Nickel's Avatar
Push Start
Last night I had to push start my car. now it turns on find.
dose anyone know what cause that problem? and if it could happen again?
(when I turn the key it click onces and thats it. first I thought it was the battery but all the lights work.)
Old Nov 27, 2005 | 02:17 PM
FrostMaxima's Avatar
I take it you mean get rolling and dump the clutch? Could be a weak battery or bad alternator, go get it checked out at an advanced auto or auto zone
Old Nov 27, 2005 | 02:24 PM
Nickel's Avatar
0k, thanks. also one of the guys that help me push my car said it could be the fusee. any ideas?
Old Nov 27, 2005 | 04:19 PM
Nickel's Avatar
can anyone help me out I dont wanna go to work on monday and be stuck
I dont get out till 12:30 AM
maby I could fix the problem before I go in
Old Nov 27, 2005 | 04:27 PM
pmohr's Avatar
No more Maximas...
You've given us just short of no information at all. What does the car do when you turn the key? Do you hear the starter engage, or the engine try to turn over, or just nothing? Does the starter just click and nothing happens? If nothing happens at all, have you had the alternator and battery checked out by a parts shop?
..like I said, we need more information. It's like telling a doctor - 'I've got some pain, but then I can make it go away. Diagnose.'
Old Nov 27, 2005 | 06:32 PM
Nickel's Avatar
0k when I turn the key it click onces and thats it. first I thought it was the battery but all the lights work.
Old Nov 27, 2005 | 06:50 PM
pmohr's Avatar
No more Maximas...
That would be your starter. Either the solenoid contacts are worn down too far, or the entire thing may have just failed.
Same thing happened on my '98 Dakota with a Nippon-Denso starter, the solenoid contacts were worn down to the point where apparently there was no good electrical connection, 9 times out of ten there was a click then nothing.
Could also be a 'dead spot', but not sure how that works.
In any case, replace your starter, problem solved.
Old Nov 27, 2005 | 07:03 PM
Nickel's Avatar
so how long will it last before my car wont start any more. cuase I need my next pay check before I can change the starter
Old Nov 27, 2005 | 07:13 PM
pmohr's Avatar
No more Maximas...
Should last the what, max 2 weeks before your next paycheck. It'll probably last for a bit (the Dakota had been on the same crappy starter with the clicking issue for at least 1.5 years), just may be harder to start as time goes on, more trying.
I wouldn't worry too much about it.
As far as starters, Autozone/Advance Auto/O'Reilly's/Napa reman' starters have been pretty hit or miss around here, some get 'quality' units, others have 6 defective in a row. I'd suggest a Nissan or Bosch reman.
Old Nov 27, 2005 | 07:15 PM
It could still just be a weak battery even though the lights work but it may also be the starter have it checked out
Old Nov 27, 2005 | 07:22 PM
DrKlop's Avatar
Driving is the next best thing
Considering that your problems started with cold weather, it could be a week battery.
Old Nov 27, 2005 | 07:37 PM
Maxima lover
I am 95% sure it is your starter solenoid. I had the same symptoms as you and finally tracked it to that. The starter worked fine when I put power right to it and avoided the solenoid. I ended up replacing the whole thing, because I figured at 100K I could use a new starter as well. Also the price for a solenoid was $40 and for the whole thing was $130.
Old Nov 27, 2005 | 09:34 PM
aznsap's Avatar
sometimes if it's not starting u can try giving your starter a whack and that will help it start. but you can only do that so many times.
Old Nov 28, 2005 | 05:13 AM
lowandslow88's Avatar
if it is your selenoid than you can start it with a scew driver...
Old Nov 28, 2005 | 11:01 AM
Nickel's Avatar
0k so next week I'll get my pay check in fix the problem thanks guys
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
240tomax
Sep 13, 2015 03:28 PM
trungg86
Sep 4, 2015 04:58 AM
