13" Cobra + Q45 / J30 Caliper upgrade possibility
Old Feb 13, 2006 | 02:34 PM
  #241
Iron Scimitar's Avatar
Tha Snatcher
Any updates?
I got some of the components and i wanted to see what i'd look like just for fun.
The rotor is a 13'' RTP Zinc. Sorry for the low light.
Old Feb 14, 2006 | 07:39 AM
  #242
Kevlo911's Avatar
Kevlo for President
How heavy is it?
Old Feb 14, 2006 | 08:03 AM
  #243
Tha Snatcher
Originally Posted by Kevlo911
How heavy is it?
pretty ****** heavy. I'll weigh everything once i get home.
Old Feb 14, 2006 | 03:31 PM
  #244
gen4maxima536's Avatar
what components are you using?
also a question.. if we use Jeffs brackets we can use the J30 TM without milling down the J30 rotors?
Old Feb 14, 2006 | 04:05 PM
  #245
Tha Snatcher
Hawk HPS pads (90-96 Q45)
13'' Cobra rotor
90-96 Q45 Caliper
Old Feb 15, 2006 | 08:48 PM
  #246
uglee_t's Avatar
Is it possible to use the 26mm rotors from the Q45/300zx w/o shaving the TM and pads?
Old Feb 15, 2006 | 09:09 PM
  #247
Kevlo911's Avatar
Kevlo for President
Read the entire thread...
Old Feb 15, 2006 | 10:26 PM
  #248
uglee_t's Avatar
I did read it... the thing is, it said that with 30mm rotors there is a need to shave the TM. So im asking whether with the 26mm rotor the TM needed to be shaved. That way it makes it almost bolt on.
Also, do you think the spacer would be necessary if runnin the smaller rotors??
Old Feb 16, 2006 | 12:47 AM
  #249
maxmaxima91's Avatar
you cannot use the J30 and the Max rotor in any circumstances... this is because if you did, the pistons on the caliper would have to come out of the body way more than there made to in order to pinch the pads on the thinner rotor. this could damage the caliper. that is why if your going to use the j30 caliper, you must use the rotor that is made for the caliper, or at least a roter of very similar thicknesses.
Old Feb 16, 2006 | 10:56 AM
  #250
SPiG's Avatar
SomePsychoGuy
I think he is asking about using the 26mm 300ZX rotor since it is the same diameter as the Q45/J30 rotor but less thickness. The Q45/J30 rotor is 28mm thick and 300ZXs have either 26 or 30mm. Using the 26mm would probably reduce the amount of grinding on the inside of the torque member, but at the expense of longevity of the rotor. It would also be lighter. You would still need to grind the diameter most likely.
Old Feb 16, 2006 | 08:11 PM
  #251
uglee_t's Avatar
Ok, since there is probably still a need to shave might as well just get the J30 28mm rotors. In anycase, what about the spacer, since there is a need for one cause of the centering to push the rotor outward slightly... stacking up washers to push the TM backwards 1/16" to center the rotor. Wouldnt that work as well?
Old Feb 16, 2006 | 11:47 PM
  #252
anyone know if this j30 setup will fit inside stock 15 or 16 in rims?
Old Feb 17, 2006 | 05:33 AM
  #253
abci30's Avatar
oh noes!!!!1111
they will fit under 15 and 16in rims
Old Feb 17, 2006 | 06:22 AM
  #254
Kevlo911's Avatar
Kevlo for President
Karim, hurry up and install these so I can see if I want the same setup
Old Feb 17, 2006 | 07:42 AM
  #255
Tha Snatcher
I gotta take care of a suspect alternator first, plus i gotta get re-manu'd calipers from AutoZone. I'm not using these old *****.
Old Feb 26, 2006 | 06:36 AM
  #256
I30tMikeD's Avatar
Well, the J30 coversion is out of the picture for me.
With the first set of calipers I got the left was the wrong part. Returned and reorderd. Went yesterday to pick it up and it was wrong again. Ended up just getting a refund for the whole thing and just installed the Hawk pads with stock rotors and calipers. Was just sick of messing with it.
So....I have a set of brand new Brembo J30 rotors and the spacers needed for the swap. Can't return them, so looking to get rid of them. Got them from TireRack, listed at $61 each. Will sell the rotors and spacers for $100 + shipping. Rotors have never been used.
I also have the stock torque members modified to work with the J30 rotors. They are currently on my car, but am willing to sell them as well if someone can provide me with their stock unmodified TM. Resonable turnaournd if someone wanted them. Will sell the TM, J30 Brembo rotors, and spacers for $140 + shipping.
Old Mar 2, 2006 | 07:12 AM
  #257
Tha Snatcher
Mild Update:
I got re-manu'd calipers from Autozone yesterday. 100 bucks for the pair...only thing is that they didn't include the TM. So i have take the TM off of my old set of Q45s in order to get my core exchange fee back. My car is at the mechanic's today. I asked them to take off the TM to me. I hope they do.
I have everything i need for the swap w/ the exception of new bolts, washers, lock nuts etc...
Old Mar 2, 2006 | 02:32 PM
  #258
Tha Snatcher
Okay, i think im set...all i need is new bolts, washers, blah blah blah...I'm just waiting for a nice day to do it
Old Mar 2, 2006 | 09:27 PM
  #259
ColdSHO's Avatar
would running q45 calipers on 04 rotors be worth it, i thought the 04s rotors were the same thickness as stock rotors just larger diameter. so according to what i think i read, thats too thin to work casue the piston would have to go out too far casue the q/j use wider rotors as opposed to larger dia like most of us are running, is that correct? i. and im running a set of 04 rotors and brackets and id like to add my new set of q calipers if theyll all paly well together. if the rotors too thin, couldnt i just use soem type of spacer to made the pads thicker, ive never heard of anythng like that tho.
Old Mar 3, 2006 | 06:21 AM
  #260
I30tMikeD's Avatar
If indeed the 04 rotors are the same thickness as stock 4th gen then yes, they would not work. The caliper piston would have to travel too far.
I have J30 rotors and the spacers need for sale.
Old Mar 3, 2006 | 08:32 AM
  #261
Jeff92se's Avatar
I'm needing a caw
Some guy is going to try this setup on a G20. J/Q calipers, my bbk brackets/rings and Cobra rotors.
Old Mar 3, 2006 | 02:43 PM
  #262
uglee_t's Avatar
I hope to have this on my G20 in a week or so. I have to say Jeff is the man for these brackets. A lil over 200 for everything is worth it for the extra braking power. Anyone else who is interested check out www.rockauto.com for blank Cobra rotors. $65 shipped!
Old Mar 3, 2006 | 03:38 PM
  #263
Jeff92se's Avatar
I'm needing a caw
Karim, pic of caliper and lines: *pic courtesy of mrgone*
Old Mar 3, 2006 | 09:02 PM
  #264
Nealoc187's Avatar
SLOW
I am as positive as I can be without having actual proof infront of my eyes that the 2k4 rotors are thicker than stock 4th gen rotors. I'm looking for thickness specs right now but not coming up with much yet.
Old Mar 4, 2006 | 12:10 AM
  #265
uglee_t's Avatar
The 2k4 rotors are definitely thicker then the 4th gens. 4th gens use 22mm thick rotors or .87 I believe.
Old Mar 4, 2006 | 12:31 AM
  #266
yea, 4th gen rotors are 22mm and 2K4 rotors are 28mm for the fronts atleast
Old Mar 4, 2006 | 02:06 PM
  #267
Tha Snatcher
Thanks bro.
Old Mar 4, 2006 | 07:50 PM
  #268
ColdSHO's Avatar
so, would the 04 rotors be wide enought to use a j/Q caliper?
im useing my stock 5.0gen caliper on them now, i figured if the 04s were wider than my stockers my stock calipers wouldnt work properly.
are my stock 00 rotors wider than 4th gens, i thought they were the same.
im not totoally ruling out he idea of spacing the pads. typaicall ythe backing of most pads is about 2mms thick. is i add one of those from lets say a stock pad and soemhow fasten it to the new pad in a way where they couldnt possibley seperate, then in theory it could work.
another thought...when a pad wears down the piston has to push farther. the difference can be up to 10mms under extreme conditionsfrom what iv noticed, im sure the piston is made to be able to accomidate wear to almost that extreme. if i just keep nonworn down pads, wouldnt the piston not have to travel as far, therefor allowing me to use q/js on 04 rotors.
i really dont want to get the z calipers id liek to be able to throw my stock rims back on if i needed to.
Old Mar 5, 2006 | 06:56 AM
  #269
muradk's Avatar
lookin for J30 brembo cross drilled rotors
im gonna do J30 brakes coversion. anybody knows where i can find cheap brembo cross drilled J30 rotors?
Old Mar 5, 2006 | 07:02 AM
  #270
MDeezy's Avatar
. . . .ebay
Old Mar 6, 2006 | 08:20 AM
  #271
Jeff92se's Avatar
I'm needing a caw
I went ahead and shipped them priority for you. Shipped sat. Note your trader rating also.
Old Mar 8, 2006 | 12:47 PM
  #272
Jeff92se's Avatar
I'm needing a caw
You just received thethe brackets/rings. Let me know how they work out
Old Mar 8, 2006 | 05:30 PM
  #273
uglee_t's Avatar
I appreciate it, my rotors come this thursday. Ill have pics up as soon as I have it installed!
Old Mar 9, 2006 | 07:47 AM
  #274
muradk's Avatar
guyz can anybody tell me if upgrade to J30 rotors and calipers actually improves our braking??? and where do those spacers go?
Old Mar 9, 2006 | 09:33 AM
  #275
I30tMikeD's Avatar
Forgot to anwser the question about the spacers in my PM. The spacer goes between the rotor and the hub, to bring the rotor out a bit.
Old Mar 9, 2006 | 11:52 AM
  #276
any one ever thought about switching to J/Q rears also? eventhough they're also single piston
Old Mar 9, 2006 | 12:31 PM
  #277
Kevlo911's Avatar
Kevlo for President
I believe they are the same as ours.
Old Mar 9, 2006 | 02:04 PM
  #278
the rear disks on the J/Qs are 16mm wide compaired to our 9, i guess just fixing the TM could allow for those to work. could be good for brake fade, with the exta venting
Old Mar 9, 2006 | 02:07 PM
  #279
Jeff92se's Avatar
I'm needing a caw
Upgrading the rears just for the thicker rotor is a waste of time IMHO. I'd say it's almost impossible to brake fade the rear maxima brakes. The bias just ins't enough to heat them up that much. If you did manage that, your fronts would be crying for mercy long before.
Old Mar 11, 2006 | 05:15 PM
  #280
MDeezy's Avatar
Ok re-reading thru the tread.
I know I'm beating a dead horse, but correct me where I'm wrong.
Say I just heard of this swap and wanted to do it. Things I would need:
Z/J/Q Rotors ( I have Z rotors 280mm x 30mm)
If I didnt want to shave the TM, I would mill my Z rotors down to 280mm x 26mm)?
If I Shave the TM, I would still need to mill the Z rotors (... x 30mm down to 26mm). Or buy some J/Q Rotors.
Use Maxima TM or trash it and buy J/Q TM?
Brake pads based on answer to above ^^ question
Spacers to go on each stud (behind the rotor?) 1/16" wheel spacer? I assume a regular washer would be too weak for this instance.
Regular Maxima lines would work or SS lines from Matt?
