Limp home mode
Old Feb 9, 2006 | 11:32 AM
JaKillz2's Avatar
Limp home mode
does it exist in a 2k se? What is it? how is it engaged? how do you get out of it? I'm just curious, nothings happened I just read about it and want to know more.
Old Feb 9, 2006 | 12:18 PM
NmexMAX's Avatar
dot dot dot ...
Your car gets home on 3 tires.
Old Feb 9, 2006 | 01:36 PM
JaKillz2's Avatar
thats all that ment? I thought it was something electrical with the engine
Old Feb 9, 2006 | 07:39 PM
Deagle's Avatar
wants the ads to die
Old Feb 9, 2006 | 08:26 PM
s0ber's Avatar
Old Feb 9, 2006 | 08:35 PM
tavarish's Avatar
fwd gone rwd cr00
lol, i thought it was just on saturns when their engines rev past 6,000 prms (waaaaaay too high) and then their engines turn on a safe mode to get you home, because you obviously dont know how to drive.
and yes, the maxima one lets you drive home with 3 tires.
Old Feb 10, 2006 | 08:55 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Ecu automatically does it. You will not be able to rev above 2700rpms.
Happened to me before.
Old Feb 10, 2006 | 10:48 AM
tavarish's Avatar
fwd gone rwd cr00
BAD MAF maybe?
Old Feb 10, 2006 | 11:22 AM
slimer's Avatar
Thats what it was.
Old Feb 12, 2006 | 10:31 AM
venturous's Avatar
Not sure about the Maxima, but it is usually related to the automatic trans where it goes back to second gear when there is a measurable difference between the input speed sensor and output speed sensor. Sometimes turning off the ignition and then back on will reset it, until it senses the problem again, or the negative terminal on the battery has to be disconnected for at least 30 seconds. This problem can occur if the trans computer detects slippage in the transmission or if there is intermittent electrical flow thru the various connections.
Randy
Old Feb 12, 2006 | 12:26 PM
MDeezy's Avatar
there were threads where it happened to various people (mainly 4th gens that I read about). The were spooked, but the car sat over night and was back to normal the next morning.
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
