Where to buy Synthetic Oil
Which is the best (and the cheapest) place to buy Synthetic Oil? As of now I am leaning towards Mobil 1. I did the search on Synthetic and read through like 10 pages but none of them had the price or an ideal place to buy it though.
Also, I understand that changing your own oil is very very easy. Do I need to jack up the car? Where are the easy step by step instrucions posted etc. I am very very illeterate when it comes to cars. I have done three mods my self though. Installing the stock CD changer in the trunk, installing the mud guards and installing the Diamond Cut clear corners (this week end) but that's about all I know about the car!! :-(
Thank You in advance for the help :-)
Re: wholesale
Originally posted by NisMoMAX01SE
i think costco has boxes of synthetic oil too now, i think its like $18 a box or something . check it out
Re: Re: wholesale
Originally posted by fisher
I just purchased Mobil 1 synthetic 5w30 at Walmart for $3.50/ quart and that was their regular price.
What is your problem
Just because you have a habbit of posting BS does not mean that every one else has the same habbit. I have also asked questions about changing the oil. FYI I have a maxima and my questions were aimed at getting information on both where to buy the oil and also is it very easy to change it or not.
I was witnessing the childish acts that you were committing by posting irrelevant posts. I think the moderators should really BAN you from this forum.
afeter killing someone if you go to court and say I am sorry will NOT get you off the hook. They will still nail you. Same way writing BS about the moderators and then apologizing does NOT solve the problems that you have.
So, if you can't stand it then please do not read my post and DO NOT reply to posts that you do not have any information to add to!
To all the others, I apologize for this. I think this guy does not have anything better to do then to engage in controversies and post ford crap! Rest assured I will not reply to his BS in the future.
Originally posted by infinitiblast
this is off topic.
this is off topic.
Re: What is your problem
don't worry about him....
as for your question...
it depends... walmart here in Houston has the same Mobil 1 5W30 for nearly $.50-$.75 cheaper than in Dallas... weird. I think you have to shop around a little.
Another example, pep boys here has Mobil 1 for $4.99.... but someone posted they get them for $4.49.
-Shing
-Shing
[QUOTE]Originally posted by dvpatel99se
[B]Which is the best (and the cheapest) place to buy Synthetic Oil?
My suggest is just of Shingles: Wal-mart or maybe K-mart is a choice.
It's a very easy steps:
1. Let your car run to normal temp and let it cool down for about 15 min before you start (That's the way I do it, other might be diff).
2. Turn your wheel all the way to the right so you have more space under the car. Pop up the hood and remove the oil cap on the engine.
3.(Optional) Jack the front up if you couldn't get under the fender. I, myself, just put a piece of carbon paper under it and slide in.
4. Lose the nut that you find under a black metal container (About 2 feet from the front). Don't forget to put the oil collector under it.
Caution: Oil and oil filter are hot !!!
5. Let it drain while remove the oil filter which locates a little further behind and on top of the oil box. Might need to use the universal oil filter remover wrench.
6.Tight the nut back after the oil had drain out.
7. Lubricate the mouth of the new oil filter with the new oil. Install the new oil filter. I suggest you only tight it up by hand so that you can remove it easier on you next oil change.
8. Refill the engine with new oil (About 4 and 1/2 Q.)
9. Start your engine...
10. You should know what to do with the rest
I hope that's help!!
Thank You
Thank You Shingles and CharlieT and all the others (except infinitiblast) that have proided this information. The next oil change will be done by myself!!
CharlieT your steps were very informative. That's exactly what I was looking for. Thanks a lot. :-)
Ok lets clear some things up here. First off I already cleared it that most of those posts were not me. I let a friend of mine that just bought a 98 maxima use my login until he signed up. Yes I did start the post about the festiva but only for fun, when my friend started answering my posts back with my username I just went along with it for awhile. Now I'm left with the clean up. Yes your right apologizing does not cover everything but it does help does it not! Your post is very relevant here I only read the topic line and not your question. I would apologize for saying off topic but you seem to think that does not help anyways.
Re: Thank You
Wal-Mart has been selling 5-quart containers of Mobile 1 for $18 or so......good deal if they still have them...that's $3.50/quart.
Costco usually has 6 quarts for around $21.50....that's $3.58/quart.
If you decide to get ramps, go for the "Rhino Ramps" (hard plastic/rubber) versus the standard metal ones. The Rhino ramps are lower and will not hit the lip of your front spoiler.
Mobil 1 is probaly the best synthetic off the shelf. For best results, use a Purolator Pure One or a Mobil One filter.
Good Luck
John
Good Luck
John
Good Luck
John
Good Luck
John
John,
I apologize for not returning your e-mail sooner.....I'll do that in a sec....
Re: Re: Thank You
Costco in Bay Area always have Castro Synthic, until recently.
I just got back from Costco (need to get some tires). While I was there, I notice they have Mobil 1 for $21.99/box. But that's only 10W30. They don't have 5W30 though.
Originally posted by bill99gxe
dvpatel99se,
dvpatel99se,
kjlouis
10-03-2015 05:29 AM
JoshG
51
09-21-2015 10:41 PM
ag90fox
09-09-2015 12:22 PM
