Best way to dry out a fog light assembly?
Old Mar 21, 2006 | 12:59 PM
n3985's Avatar
大陆弟弟
As I took out my foglight yesterday and saw condensation on the lens, I turned it over and a puddle of water came out. So I shook it back and forth and more drops came out. But still inside remains more water droplets, how can I dry it out completely? Should I just let it hang upside down for a day? Thanks
Old Mar 21, 2006 | 02:58 PM
StL I30's Avatar
Bake it in the oven at 175 degrees for 10 minutes intervals until it's gone.
Wet towel on cookie sheet. Fog on wet towel.
See any cracks anywhere? If no, throw some silicone around where the lens meets the housing and you'll be good to go.
Old Mar 21, 2006 | 02:59 PM
StL I30's Avatar
Oh yeah, don't let it hang to dry. You'll get watermarks and than you'll have to take the fog apart to get them out.
Old Mar 21, 2006 | 03:57 PM
n3985's Avatar
大陆弟弟
OK, thanks for the info.
Old Mar 24, 2006 | 05:41 PM
A_Tang's Avatar
Originally Posted by StL I30
...throw some silicone around where the lens meets the housing and you'll be good to go.
I was thinking that silicone would eventually harden and peel off. Perhaps something that penetrates the crack would be better? Thoughts?
Old Mar 24, 2006 | 05:44 PM
CanadianMoFo's Avatar
Cover the outside of the lamp housing in soapy water. Blow into the hole and if there is any bubbling you know where your leak came from. Seal it up with silicone. Its designed not to harden over time. Works like a charm. Also replace your bulb as it could be the o-ring the base of the bulb that is leaking.
CM.
Old Mar 24, 2006 | 07:51 PM
n3985's Avatar
大陆弟弟
I had water in mine because the H3 bulb cap was lose and therefore water got in. I baked it at 175 for 20min and it dried out nicely.
Old Mar 30, 2006 | 06:31 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
I'm looking at some sik *** fog lights for a 00 - 01 and wanted to know if it would fit my 03 model. Wanted to make sure before I picked them up. Thanks.
Old Mar 30, 2006 | 06:33 AM
n3985's Avatar
大陆弟弟
Don't hijack my thread please....
Old Mar 30, 2006 | 08:13 AM
HTPerformance's Avatar
ummm... borrow the gf's or mom's hair dryer?
Old Mar 30, 2006 | 08:28 AM
n3985's Avatar
大陆弟弟
Answer has been posted..../thread
Old Mar 30, 2006 | 08:34 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Just another suggestion...instead of baking it, you could wipe the inside down with rubbing alc. It will displace the water and leave the inside bone dry.
Old Mar 30, 2006 | 09:02 AM
n3985's Avatar
大陆弟弟
I30/I35 fog lights have a tiny opening, will be difficult to wipe inside, but good suggestion.
Old Mar 30, 2006 | 09:44 AM
NP, man. In all honesty, you could put a little in the hole, plug the hole with your finger, shake it around, unplug the hole and let it evaporate. Just a possible alternative, I hate putting car parts in the oven.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
minsbang
Sep 11, 2015 08:48 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxima30
Sep 7, 2015 06:13 PM
