What's the perfect A/F ratio on a wideband O2?
Old Jun 13, 2001 | 11:32 AM
1MAX2NV's Avatar
Anyone know? What is a real world safe A/F ratio on nitrous? I don't mind running a little rich, but not to a point where I'm loosing major HP.
Old Jun 13, 2001 | 11:53 AM
MardiGrasMax's Avatar
12.6-1 to 12.5-1 is where I was at and I was getting ~82hp at the wheels out of a 100hp jet.
go here to see my dyno with a/f and hp
http://www.zing.com/picture/pb26de95...2.jpg.orig.jpg
Old Jun 13, 2001 | 12:30 PM
1MAX2NV's Avatar
12.6 is really good. You are just alittle rich. I think 13.1 is perfect for the real world.
Old Jun 13, 2001 | 01:12 PM
When are you going to the dyno?
Old Jun 13, 2001 | 08:44 PM
1MAX2NV's Avatar
The car was dynoed today. I couldn't be there, but I got a the print out. I will scan it when I get a chance. He dynoed it in second gear. With 80 shot, I'm only getting extra 41hp to the wheel. He said it's due to my auto tranny. My A/F is also on the lean side. Range from 14.2 to 13.5. I have no idea what jet sizes I'm using. My installer said they were the smallest one from the kit. I called NOS and the smallest jets for my kit are .22 for nitrous and .16 for fuel. Does that equal to 80 shot? I'll hit the track next friday. I want to be aleast in mid 14s, I might step up another 20 shot to get there. My car never really responded will to mods. I got around 7hp with UDP and Y-pipe. The catback did nothing. The intake made the most difference.
Old Jun 14, 2001 | 06:01 AM
I think you'll see mid 14's.
Their is no way your auto tranney is sucking up ~45% of the 80 hp shot. Your a/f ratio does bother me, I'm no expert on dyno tuning but nitrous needs fuel to make power. Have you asked the NOS tech department about the a/f ratio and what hp level the jets are for?
Old Jun 14, 2001 | 06:46 AM
1MAX2NV's Avatar
The .22 nitrous and .16 fuel jets suppose to be 80hp according to NOS. Is there a way to look at the jets to tell what they are? Are there numbers stamped on them? From looking at NOS's suggest tuning chart on their website, fuel jets usually are bigger than nitrous jets. I will step up to the next fuel jet size to see what happens. Maybe like you said, I'm really starving for fuel.
Old Jun 14, 2001 | 08:44 AM
1MAX2NV's Avatar
NOS tech was really puzzled. As lean as I'm running, I should be making more power. I pulled the plugs last night after some runs. They looked ok.
My bottle pressure is around 950.
My WOT fuel pressure is around 52psi
NOS tech suggest I drop the bottle pressure down to 850 and see if that helps before changing the fuel jets.
Only thing I can't verify are the exact jets I'm using since I didn't install them.
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
BkGreen97
Apr 2, 2016 05:47 AM
Serotta33
Sep 17, 2015 12:14 PM
