For those with 300ZX calipers...
Old May 18, 2006 | 08:01 PM
UMD_MaxSE's Avatar
Got Bent?
I was wondering of anyone else with 300ZX calipers ever has this issue or has had it in the past. I have noticed that my right side brakes make a creaking sound when I press the brake pedal. I've found that they are quiet when the brakes are cold but get noisier as the brakes warm up. Pads are worn about half-way through and rotors are also wearing perfectly normal on both sides. Caliper pins and, from the looks of it, hardware shims and clips are all smoothly moving and in place. The noise starts as I depress the brake pedal and stops once the pad hits the rotor. Braking response and force is just fine. No issues at all other than this creak.
I did some research on google and found this thread on some UK 300ZX forum:
http://www.300zx.co.uk/forum/showthread.php?t=35935
seems like my issue. Just wondering if anyone else ran into this...
Calipers were completely rebuilt 30k miles ago and seals look just fine. No leaks at all. I am going to try and replace the pads and swap rotors for blanks instead of the slotted ones I have in there now... hopefully that does the trick
Old May 18, 2006 | 08:04 PM
Kevlo911's Avatar
Kevlo for President
Same prob except it is the left side for me I dunno if its a creak tho. It's like wooooooooo woooooooo woooooooooo
Old May 18, 2006 | 08:07 PM
UMD_MaxSE's Avatar
Got Bent?
open the window and it sounds like a metallic-type creak. Nothing extremely loud, just annoying. I think it happens when the pads are worn more than half-way... never had it with newer pads. These have 30k on them now.
Old May 18, 2006 | 08:27 PM
Kevlo911's Avatar
Kevlo for President
My pads are new though. Wierd. I can live with it.
Hopefully the Hawk HPS won't do it.
Old May 18, 2006 | 08:29 PM
UMD_MaxSE's Avatar
Got Bent?
I have Axxis/PBR metal masters in there now... I've always liked them since they seem to hold up farily well under heavy braking. A little bit dusty and noisy, but they perform well. I have a set of new ones waiting to be installed...
Old May 18, 2006 | 08:34 PM
Matt93SE's Avatar
STFU n00b!
common issue. remove, clean, and grease the slider pins holding the pads in. what's creaking is the dry metal-on-metal of the pads vs the pins when you press the pedal down.
easy confirmation: remove the pins from the caliper and stick a small wire or something in there to hold the pads in place. now go stomp on your brake pedal (don't go drive, just press the pedal), and you'll notice the noise is gone.
Old May 18, 2006 | 08:41 PM
UMD_MaxSE's Avatar
Got Bent?
I thought it was the pins so I did grease them up a bit. I never took them out to do it, but they do rotate freely. I probably should have removed them to do that though thanks for the advice!
Anyhow, the pads are going as well as the rotors so it will get taken care of then... I can't stand the noise/vibration from these slotted rotors blanks for me from now on...
Old May 18, 2006 | 08:44 PM
Kevlo911's Avatar
Kevlo for President
Yupp, I plan to get rid of these slotted rotors tooo.
Old May 20, 2006 | 09:07 AM
Kevlo911's Avatar
Kevlo for President
What kind of grease should I use?
Old May 20, 2006 | 09:11 PM
UMD_MaxSE's Avatar
Got Bent?
that nasty high-temp brake grease... comes in packets... orange/copper color I think...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
