NOS INSTALL. Tips, Ideas, Extra Instructions, ect...
Maxima.org Sponsor and Donating Maxima.org Member
Ok i'm finally gonna start install my nitrous kit and i'm just looking for any tip, hints, extra instuctions and such that i should know before i get too into this. I have the JC Whitney kit and i'm ordering the fuel pressure gauge and Nos bottle pressure with a tranny cooler and some other odds and ends. But what i'm worried about is any hurdles during the install or anything that i should watch out for. ANY INFO WILL BE APPRECIATED AND MY VQ WILL APPRECIATE IT TOO WHEN IT'S STILL IN ONE PIECE.
Originally posted by medicsonic
If you haven't done this before, I would SERIOUSLY suggest that you get it professionally installed. Seriously.
I doubt.....
you wanna "learn" with NOS...if not installed right the consequences could be disastrous! I'm all for expanding knowledge in modifications, but with something as serious as NOS, proper installation is a big factor!!
Originally posted by dmbmaxima88
you gotta learn sometime.
Take your time, double check it, double check it again. You can check all the electrical connections with a voltmeter, etc.
Be sure the fuel pressure goes up when you hit it before you try it with the nitrous jet. To do this after you have it all hooked up, disconnect the electrical to second solinoid (the one with the line that goes to the air intake) and make a pass, when you hit the button the fuel pressure will rise up and the motor will mabye stumble a bit or just feel kinda weak, if not the fuel pressure is not rising. Once you get the fuel pressure up, start with the smallest nitrous jet in your kit (0.032 - 40hp?). Check your plugs for silver specs or blue glazing on the ground strap. If you can get to the highest jet in your kit (0.036 - 60hp?) with out seeing specs or bluing on the plugs your set. However if you see any signs of specs or bluing drop back down a nitrous jet because you have reached the limit of your fuel system.
E-mail with questions...
Ps: Dont huff the nitrous during the install you might F somthing up, wait till after please
There are a couple of things that i guess i can throw ya way. First off, you can isntall it yourself. It is very easy to do. Just be patient and make sure you understadn the instructions. People will never understand this.
I would install it once you get everything but if you cant wait, go for it! That is what i did. hehe. I have noticed though since i keep adding someting new to it every week, it is beginning to annoy me sinc ei am taking half the thigns apart and putting it back together.
Remember to go out and buy some brass fittings for your FPSS, i believe the threading on it is 3/8". Also go get some teflon paste to use on all fittings.
The aluminum fittings are easy to destroy. I have done this once and costed me $15 for a littel blue fitting.
Also, make sure the nozzle is pointing towards teh TB and not any other way. Also, make sure you adjust teh FPSS right or it wont spray.
The JC Whitney kit comes wiht a 50, 60, & 70 shot.
Originally posted by sx7r
actually, the FPSS has a 1/8" male fitting. since you're getting a fuel pressure gauge you'll need to get brass fittings for that too. the electric sender should be 1/8" also.
ya the fuel gauge i am getting has a 1/8" sender. what kind of a/f gauge r all you running?
I know Thomas (SX7R) is running all Autometer as well. Phantom a/f gauge, Ultra Lite FP gauge, and i think Phantom for EGT. I could be wrong. I do know for a fact they are autometer.
I also know mardigras (matt) is running a custon a/f gauge. I think he mad his, if you want to do that, PM him on that.
I am running all Autometer Phantom Gauges, this includes my EGT, FP, & A/F.
Ya i'm looking at all Autometer 2 1/16" gauges, A/F, FP, and Nos Bottle pressure by someone else. I'm gonna get the dual gauge pod and a bracket like thomas. I'm gonna order them later today. anything else i should order from summitracing while i'm there. Oh ya, what size bottle pressure guage, 4an or 6an?
I am using a Nitrous Xpress (NX) pressure gauge. This onlyu costed me $20 and the gauge is liquid filled to be more accurate. I had to buy an adapter for this which set me back another $15. I know its nota 8an, i think the bottle is 4an. You know the "Tee" fiting for the soleniods? You know the blue one that goes right in between the soleniods, that is a 6an ( i am positive, i had to buy a spare one of this), and check if that is teh same threading on teh bottle, if it isnt, then its 4an. I'm pretty sure its 4an but i have been wrong. FIY-there are 2 different bottles, 1st gen and 2nd gen bottle, we had teh 2nd gen bottle. They are a little bit different.
Originally posted by Screaminfast
Just a random question:
Which Fuel Pressure Guages are you running? Full sweep or half-sweep. I know the price difference is like 150 bucks.
Oh DMB- i forgot to mention when you buy the EGT, you will have to buy a probe for it. Mine costed me $50 for it. My needs to be welded in but they do sell teh ones that can be clamped into your exhaust. I would not sugguest installin it till you have a y-pipe. Drillin into the OEM y-pipe is bad, sucker lists for $1200 from dealer!
Re: I'm thinking about ordering
Originally posted by primeevil711
Aside from what comes in the kit that JCWhitney provides, what would I need to have a complete NO2 system? When I order the kit I plan to have pro install, and should I get cold type spark plugs?
-Purge Kit
-WIndow Switch & Pills
-Bottle Heater
-Remote Bottle Opener (optional)
-EGT Gauge
-A/F gauge
-FP gauge
-NOS pressure gauge
-Brass Fittings for teh FPSS & FP gauge sensor
-Gauge Pods
-Teflon Paste
-A long copper tube extension for the purge kit
As far as plugs, people will say use a copper plug. SOme others will say using platinum will be fine too. I have used both and have noticed nothing different and they were in great condition after i sprayed. I use teh NGK PFR6B-11 they are plat. plugs.
Re: Re: I'm thinking about ordering
The JC Whitney kit is a basic NOS kit. I would get the following for a full complete NOS kit (This also includes the extra stuff you need):
-Purge Kit
-Bottle Heater
-EGT Gauge
-A/F gauge
-FP gauge
-NOS pressure gauge
-Gauge Pods
-Teflon Paste
-Purge Kit
-Bottle Heater
-EGT Gauge
-A/F gauge
-FP gauge
-NOS pressure gauge
-Gauge Pods
-Teflon Paste
Re: Re: Re: I'm thinking about ordering
how much do you think all that stuff will cost? and if I put the basic kit on first can I add it later?
Re: Re: Re: Re: I'm thinking about ordering
If you get teh JC Whitney Kit at the special price plus all that, you are looking aorund $1000 total. Yes, you can ptu teh basic kit on first but then you wil have to take half if it apart to add more things on. That is what i did and now wished i did it all at once. WIth NOS, its always good to ahve more then you should jsut to be safe then sorry ya know?
Yes, you can put in the kit straight from the box and run it like that, but its kinda like driving without an instrument panel, you just have to hope that everything is okay.
maxima297
09-30-2015 03:32 PM
