checkup MAF with multimeter
i saw or was involved in a thread that dealt with this a while ago. i never got an answer. when i just poked around with the probes i ended up shorting the signal and the engine sped up, then i checked the dash and i threw a SES light and MAF code. so i don't recommend my version of 'backprobing', meaning pressing the lead into the foam stuff until you hit wire and short the signal. i'm guessing that you could get these values by probing the ECM, but that's more work than i was going to do.
If you have the SAFc set-up correctly you can see it as well as TPS/RPM etc...
Anyhow, anything ~or over 4.75v should read 100%.
Instead of using that, why dont you just test the MAF w/ a multimeter?
TallTom
50
07-08-2022 09:54 AM
ballerchris510
09-10-2015 09:35 PM
