Going on a trip tomm.........question....
Old Oct 19, 2000 | 08:43 PM
Mike S.'s Avatar
I have a 93gxe...intake and y-pipe. I always use 93 but I don't have a modded ecu or adv timing. Should I just run 87 for the trip? I mean...i'm gonna have the cruise set between 75-80 the whole time, Buffalo-Boston. In the past I have not been able to tell the diff between the two but just wondering. In the end its only a couple bucks more to run the 93...only like a .10 more a gallon.
Mike S.
Old Oct 19, 2000 | 08:46 PM
tclee's Avatar
pay for the 93 octane...even though its $.10 more...even if you can't tell the diff...etc piece of mind you know?!
rgds
Old Oct 19, 2000 | 09:59 PM
Nismo87SE's Avatar
It depends on your load and if your going to use your AC or not. With stock timing you should be able to get away with midgrade. But 87 octane will cause your knock sensor to retard timing more than normal. IMHO if you did run 93 octane you need to advance your timing at least 2-3 degrees. The extra 4lb-ft in the lowend will surely be missed without timing tweak. I say go mid grade remember don't tolerate any knock or pinging at all.
Old Oct 19, 2000 | 10:06 PM
Mike S.'s Avatar
cool beans.....
I think I'm just gonna stick with 93....besides I'm splitting the cost of gas with my passanger(115lb female )
I'm 150lbs so load aint gonna be a problem The weather is going to be goregeous....60 and sunny into Sunday..no ac needed.
Thanks,
Mike S.
ps-I think I'll advance my timing when I get back.
Old Oct 20, 2000 | 09:39 AM
Alexander's Avatar
You can save a few dollars by filling with 91 if it's available in your area - it's what Nissan recommends (not 93).
- Andrew
Old Oct 20, 2000 | 10:02 AM
My 4DSC
In my 00' Max...i only use Sunoco Ultra 94....
and I'm paying out the @$$ for it too... avg $1.79/gallon.
I'm actually saving $$ since i got rid of my Civic, though!
Used to HAVE TO use a mixture of Ultra 94 & Cam 2 (100 oct)!
Now THAT hurt my pockets... $1.79/gal + $4.65/gal.
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
gigabyte
Jan 6, 2017 06:05 PM
Andy29
Sep 29, 2015 05:32 AM
Bonka
Sep 14, 2015 11:18 PM
