Installing NOS Fuel Pressure Switch
Old Jul 30, 2001 | 03:57 PM
Ramius83
Ok, there are two ways to install the fuel pressure switch for a NOS EFI Dry Kit. It says you can either install in on the fuel rail test port or on the outlet port of the fuel filter (if it has a banjo type fitting). I looked today and since the Maxima is a later year fuel injected vehicle, it does not have the fuel rail test port. And the fuel filter does not have the banjo type fittings. So where did you all with NOS install it at? Thanks for your help. I have been working for a few hours on this project and so far so good. Thanks again.
Old Jul 30, 2001 | 09:06 PM
Ramius83
Anyone?
Old Jul 31, 2001 | 07:51 AM
1MAX2NV's Avatar
You need some barb fittings for the hose and 3/8" T fitting. I think that's the size. Bascially, take the FPS to a domestic speed shop. Tell them you need some fitting so you can put the FPS between two hoses.
Originally posted by Ramius83
Anyone?
Cotozic
Jun 28, 2017 08:01 PM
kmitchel
Oct 28, 2015 09:46 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
