airbag warning light showed up today
Old Aug 1, 2001 | 06:32 PM
DhaMax's Avatar
i was installing my turbo timer today, and as told in haynes manual, i disconnected the airbig plug from underneath the steering wheel(so they will not deploy by accident, when working with ecu)and after i was done, the air bag light started blinking (malfunction). i even restted my ecu, but no go. any suggestions?
Old Aug 1, 2001 | 06:35 PM
Sprint's Avatar
did it ever occur to you that because you disconnected it that the ECU is going to freak out... the only choices you have is to plug the sensor back in or ignore the light... and why do you have a turbo timer if you don't mind me asking
Old Aug 1, 2001 | 06:41 PM
DhaMax's Avatar
i was only following instructions, i did not want to take a chance of deploying them and pay 5000 to repair. i got a turbo timer because it is a cheap gtech pro mod, and rather accurate.
Old Aug 1, 2001 | 09:16 PM
MaineI30's Avatar
Did you plug the airbag sensor back in??
Old Aug 2, 2001 | 03:28 PM
DhaMax's Avatar
yes everything is plugged back in, i even checked the main unit under the center console. so i even checked the air bag fuse inside the car. good as new. so i just disconnected the warning light.
any sugggestions welcome
Old Aug 2, 2001 | 04:48 PM
Sprint's Avatar
just how exactly did you reset the ECU?
Old Aug 2, 2001 | 05:57 PM
DhaMax's Avatar
by having the ignition key in on position. then turn the screw clockwise wait 2 seconds and turn it back. repeat once or twice simultaneously. (written in haynes) i even disconnected the + battery terminal for about 10 mins. still the same.
Old Aug 2, 2001 | 06:08 PM
Sprint's Avatar
well you did it right so.. i dunno..
Old Aug 5, 2001 | 04:14 PM
whitemax99gle's Avatar
My airbag light came on and I didn't do anything to it. Any problems that may occur? I have 27,000 miles on the Max.
Old Aug 5, 2001 | 07:23 PM
MaineI30's Avatar
Maybe you should ask your dealer?
Trin1j23
Aug 12, 2015 08:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
yat70458
Aug 3, 2015 01:16 PM
