Clutch / Rear main seal replacement
I recently got an ACT clutch (thanks Brian) and am having a mechanic I know at the Nissan dealership install it. In addition to having the clutch installed and the flywheel reground, would it be wise to also have the rear main engine seal replaced while they have the transmission off? My car is a 97SE with 74k miles.
How much does a rear seal cost?
Are there any other preventative things that I could have them do that require the transmission to be removed?
The seal on my used motor was actually a new one but wasn't seated properly, I just reseated it and so good do far. So I didnt have drop the upper oil pan.
Originally posted by Jeff92se
Yes, might as well do the main seal. It doesn't cost that much. Other things. Get the two output shaft seals replaced on the tranny. Again the seals are cheap.
Don
vingodine
45
05-21-2016 12:46 PM
Huttig2009
09-25-2015 03:31 PM
MAXSE5SPD
08-23-2015 12:06 PM
carlosvq30
08-17-2015 11:32 AM
