Annoying rattle/buzz from inside my muffler from 2300-2500rpms
Old Oct 19, 2001 | 10:06 PM
Dave B's Avatar
Not DAVEB the parts guy
For the past 3 months, I've had a rattle/buzz that comes from my exhaust in 1st and 2nd and occurs from 2300-2500rpms. At first, the rattle/buzz went away after the exhaust warmed up. Now it happens all the time. I use to think it was a catalytic brick that came loose inside my RT cat. I removed the RT cat and the sound was still there. I've removed my whole exhaust and inspected everything and the rattle/buzz is still there. The sound only seems to come from the muffler (stock). Has anyone had this problem before?
Dave
Old Oct 19, 2001 | 11:06 PM
emax02's Avatar
Re: Annoying rattle/buzz from inside my muffler from 2300-2500rpms
Dave
My Y-pipe makes my muffler have a buzz at 2200-2600 RPM. Maybe it's the cause of a "not so good" flex section in your Y-Pipe.
Old Oct 20, 2001 | 06:24 AM
CoOlKidS1979's Avatar
I doubt you have the same problem, but on my car the problem was from the license plate holder in the rear. The 2 bolts that hold the top of the license plate were to long and they were hitting a metal directly behind the rear bumper, so when I was at lower rpms I think the muffler would cause the license plate to shake causing the sound. At least thats what happened on my car.
Old Oct 20, 2001 | 07:21 AM
Eric99SE-L's Avatar
Your muffler sounds like it's rusting from the inside out.
Old Oct 20, 2001 | 08:59 AM
96sleeper's Avatar
it's the muffler
I don't have the stock muffler, but mine is doing the same thing. It started out as a rattle or a buzz only when the car was cold, but now it rattles and sounds like a cow bell when its cold and buzzes slightly when it is warmed up. The inside baffle on my muffler is broken. I was told I could take it and have the inside welded back in, but I am not sure.
Old Oct 20, 2001 | 10:14 AM
Dave B's Avatar
Re: it's the muffler
That's the sound. Thanks.
Dave
Old Oct 20, 2001 | 10:32 AM
Dahnryman's Avatar
dave?
do you need a stock muffler...? mine has a tip welded on it but it dosent make a rattle sound or anything....i am sure i could help you out with it when i get my new one...
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
mpbclutch33
Dec 26, 2015 11:11 AM
