Battery Light/Brake Light
Old Oct 22, 2001 | 08:12 AM
SnOwBoaRdRXX's Avatar
I drove to class this morning no problem, parked the car, then went to class. I get in my car after class, start it up, and the Battery light was on as well as the brake light. I dont use my ebrake that often, I played with it, putting it up and down. No dice.. Could this be a fuse problem? or did my car just **** the bed?
Old Oct 22, 2001 | 08:16 AM
«§»Craig B«§»'s Avatar
Re: Battery Light/Brake Light
check your brake fluid under the hood
brake light means the emergency brake is on OR low brake fluid
Old Oct 22, 2001 | 09:09 AM
The brake fluid is filled the Max. I checked the ECU and got: No Failure Recorded/Detected. The alternator is humming a bit louder than usual.. but, the belt wasn't loose. Should I send it to a mechanic?
Old Oct 22, 2001 | 09:22 AM
Sprint's Avatar
take it to pepboys or autozone and have them test your altenator for free
Old Oct 22, 2001 | 10:20 AM
Enduro's Avatar
Pepboys will charge ~$16 but Autozone will do it for free. Sounds like you have a charging system problem.
Old Oct 22, 2001 | 12:33 PM
mrdeucie
don't know if it's true on the max but when both those lights come on it means the alternator is faulty.
Old Oct 22, 2001 | 01:06 PM
How much is a supercharging alternator gonna cost me? Is it close enough where i can throw it on the credit card, have the folks pay it, and think they just bought a regular alternator?
Old Oct 22, 2001 | 01:13 PM
Sprint's Avatar
get a regular one
Old Oct 22, 2001 | 04:27 PM
Enduro's Avatar
Definitely will cost more than $270, which is the price for OEM REBUILT alternator. Good luck finding non-OEM ones cause Pepboys, Autozone, and Lappens were all out of stock for awhile when I was searching for one just couple weeks ago.
Also do you do alot of idling with lots of accessories turned on like headlights, extra fogs, a/c or heat, and running amps all at the same time? If not then regular alternator will do just fine.
Old Oct 22, 2001 | 05:21 PM
Would resetting the computer do anything, instead of just checking it.. Could I just take the negative off the battery for 10 minutes?
Old Oct 23, 2001 | 05:13 AM
Enduro's Avatar
Don't do that. I asked this question earlier and the final answer I got was a big NO and the reason sounded right.
Your battery serves to protect against voltage spikes. Since u're already suspecting a possible bad alternator the voltage regulator could fail and produce too much voltage momentarily. Without the battery there to absorb some of it your electronic components could be in jeopardy!
A free battery/alternator test at Autozon is much free(er)? than fixing fried electronic components
Old Oct 23, 2001 | 10:15 AM
Hey remind me not to go to midas ever again... 500 for install of 110v alternator and they keep the old one.. I only did it cause every other garage said it would take a few days, and midas said 3 hours
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
