when ur tranny starts to slip...
Re: when ur tranny starts to slip...
i reply and i dont know the exact answer.. BUT, i am almost positive that slipage is the valve body, only because Don's recalibrated VB makes shifting faster and firmer.. mine is still under warranty so i think i am gonna have nissan poke around under there..
what happen to the other answers?? I think Medic was right, its the revers clutches and all that good stuff, I don't think the VB has anything to do with it. my tranny died 3 times and every time it was a bad band, nothing to do with the VB??
oh btw sprint: i have asked the moderator to remove all spam...so if u would be respectful enough...please don't spam cuz i'm asking a serious question and would like a serious answer...
Originally posted by Yellowbrother
what gen do u have???
but I'm 99.9% sure its one of the clutch bands like Medic said, I seriously doubt the VB even comes into play when the tranny is about to die!
1991 GXE(3rd gen)....we were the ones who Nissan decided to give the ****ty POS clutch bands to!
well so far it's not too bad...the only symptom i've had so far is that it takes foreva for the tranny to catch first gear...when i first put it into drive...
just for kicks before someone try to get smart and say search....well i did a lil search and found this....
What does a VB, TC, or tranny cooler do?
VB mod = valve body modification. Basically, tunes the valve body in the tranny to allow faster, quicker shifts. Slipping is elminated and tranny will eventually last longer.
Tranny Cooler = A radiator-like cooler for the transmission fluid. You need to get this if you have your VB recalibrated. The VB will make for faster shifts and your tranny fluid will run hotter. Heat is very bad for a transmission. The tranny cooler will keep the fluid at a lower temp. You can get this even without the VB mod.
TC = Torque Converter. Your auto has this already, but a stronger TC will increase your stall speed and transfer more power from engine to drivetrain. You will be able to get better launches and will lose less power than you would with your stock tranny.
Credit: UMD_MaxSE
Credit: UMD_MaxSE
pktaske
05-06-2016 07:49 AM
QueensMAX
09-15-2015 04:14 AM
pktaske
09-04-2015 08:40 AM
