Those with AFC Step in
Old Nov 22, 2007 | 09:43 AM
DrunkieTheBear's Avatar
Turbo'd Saab
I have an Apexi Neo and yesterday kyle(MOHFpro) and I were installing it in my car. We checked every wire after we connected it, starting with the Power source, then the RPM and it worked, then the throttle signal and it worked, but when we started the car it stalled. All the settings were at there defaults. So my first question is, will it make that much of a difference by not having the airflow sensors wired to the AFC?
My second question is, what is everyone else running for there settings for the maps and there in out settings as well?
Old Nov 22, 2007 | 10:31 AM
DasYears
well if you dont have the airflow sensor connected it wont make any corrections. you should have setup the afc a little before starting. you need to calibrate the throttle and rpm, set it to 6cyl and up/right arrow. then you can start it.
Old Nov 22, 2007 | 10:41 AM
kzoosho's Avatar
if you read the directions it clearly says dont start till done with setting up the afc. Make sure all of your connections are good go through the setup then start the car.
Old Nov 22, 2007 | 10:47 AM
Turbo'd Saab
I should say that I did do that.
sorry forgot to mention that.
it stalls the first time and then the second time you start it, it will run but very rough
Old Nov 22, 2007 | 10:56 AM
kzoosho's Avatar
Please go back through and cheack all your settings the check your conections. That would be the next step. Also post what readings you are getting with te car off. One more thing what is yousetting of the tps with no gas and wot?
Old Nov 22, 2007 | 10:57 AM
NmexMAX's Avatar
dot dot dot ...
My guess: IN/OUT is not correct.
Old Nov 22, 2007 | 11:10 AM
Turbo'd Saab
in out is at default 1/1
tomorrow will be the second attempt
Old Nov 22, 2007 | 11:30 AM
kzoosho's Avatar
I was thinking that 2? what in and out to run on a 5th gen? I know mine were 4 in and 4 out
Old Nov 24, 2007 | 01:37 PM
NmexMAX's Avatar
dot dot dot ...
As long as the ratio is 1:1, (1:1, 2:2, 17:17, etc...) IIRC, 5th gen is 17/17, but I've used 1/1 and it worked fine, hence my theory above.
Old Nov 24, 2007 | 03:28 PM
kzoosho's Avatar
Well you would know better than me.
Old Nov 24, 2007 | 03:44 PM
dfownz's Avatar
Yeah 1in 1out's fine
I've been set to that forever now.
Old Nov 25, 2007 | 07:42 PM
maxspeed96CT's Avatar
The original VQ...
you gotta make sure you cut the maf wire and not just tap into it.
thats the mistake i made when i first wired mine.
It was a qwk fix tho.
Old Nov 25, 2007 | 07:44 PM
kzoosho's Avatar
And make sure they are in the right direction . I did that also.
Old Jan 12, 2008 | 04:26 PM
black box's Avatar
black box SE06
anybody know the setting,the pin-out and the wires colors on the S-AFC for the A34 6thger. maxima?
gigabyte
Jan 6, 2017 06:05 PM
JoshG
51
Sep 21, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
