Wheel noise that STOPS with acceleration...
Old Jan 10, 2008 | 07:49 AM
BJGemini's Avatar
Hello, all, long time no see (few years, actually)!
I searched (not just on maxima.org) but only found wheel noise that worsened with acceleration.
The noise:
-sounds like a grinding/friction
-stops with acceleration
-appears to be in same frequency as rotation of the wheel
-present with coasting and braking
-doesn't occur with physically pushing down or leaning on that side of the car
-is not felt in the brake or the wheel
Any suggestions???
Thanks in advance!
-Brian
Old Jan 10, 2008 | 08:19 AM
Pearl93VE's Avatar
I can has?
You could have a warped rotor/uneven brake pad wear. Take off the wheel that makes said noise and check the rotor to make sure it's smoothish and flat, also check brake pads to make sure they're bedded down correctly. This happened on my cousins third gen and we had to replace the whole rotor because for some reason the pad was digging into the rotor really hard. Concaving the entire rotor over time.
Old Jan 10, 2008 | 08:33 AM
BJGemini's Avatar
thanks - will check later!!
Old Jan 10, 2008 | 08:48 AM
ghostman1000x's Avatar
Sounds like metal to metal on a portion of the pads
Old Jan 10, 2008 | 09:34 AM
BJGemini's Avatar
Just bc I've gotten suggestions from other, rather knowledgeable sources, what would a strut mount or a bushing noise sound like?
Old Jan 11, 2008 | 11:40 AM
Machinist's Avatar
but you said....
"doesn't occur with physically pushing down or leaning on that side of the car"
Old Jan 11, 2008 | 02:17 PM
AllBlackMax's Avatar
aka The Doom Ship
Having almost the exact same problem. I let my girl drive my car and I stood outside to see if I could hear it outside of the car. I barely hear the sound from the outside. From inside the car I hear this .......grind.......grind.......grind. Exact intervals. Coming from my driver's side front wheel area.
Old Jan 11, 2008 | 03:39 PM
Pearl93VE's Avatar
I can has?
take off the wheel and look??
Old Jan 11, 2008 | 04:07 PM
aka The Doom Ship
duh, there's no visible rubbing.
Old Jan 11, 2008 | 04:29 PM
vqmaxman's Avatar
Two things can be done here.
1. put the car on the jack stands then try to spin the wheels check If It spins freely and It should. The car has to be in N.
2. If The wheel hubs are gone bad and wheels should not spin and It should feel hard. I am assuming your brakes are ok and your rotors are too.
Old Jan 11, 2008 | 05:26 PM
MR.BEANZ's Avatar
I would say check the hub and bearing. Usually can make a lot of noise when they are going. Jack up the car and try to shake the wheel, if it has a little rattle or play, bearings need changing. Just my 2 cents!!!
MR.BEANZ
Old Jan 12, 2008 | 12:04 PM
Delvin's Avatar
I'd put my money on hub bearings. When coasting try shifting the weight side to side buy slightly swerving left to right and see if you can duplicate the noise. Another way to check bearings, adding to what MR.BEANZ just mentioned, is to rotate the wheels and grab on to the spring while its spinning. You need to have the front wheels off the ground and the car in neutral to do this test. While spinning the wheel and grabbing the spring you shouldn't feel anything in the spring at all. If you feel a 'gritty-like' feedback in the spring then the bearings are bad.
Old Jan 12, 2008 | 12:47 PM
aka The Doom Ship
Last time my front passenger side bearing went it made a knocking sound not grinding but who knows...
Old Jan 12, 2008 | 04:43 PM
Delvin's Avatar
Bearings are like girlfriends.......they let you know when its time to replace them but never the same way as the last. I had a noise that sounded like something was hitting the floorboard of the car under the drivers seat and low and behold it was the wheel bearing.
fastcarny
Oct 6, 2015 10:42 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
