Gforce ECU *TRACK PROVEN* 14.3 NA 5speed!
Old Oct 24, 2001 | 09:47 PM
  #41
nizmolee's Avatar
Originally posted by BrianV
I
Also, freeway gas mileage is improved significantly with the ECU (don't ask?)
how is gas improved? ECU lighter in weight.. hehhe
Old Oct 24, 2001 | 09:49 PM
  #42
BrianV's Avatar
We did that at Carlsbad, ran a 15.4 and then a 15.1 one run after another.
Old Oct 25, 2001 | 02:53 AM
  #43
Sprint's Avatar
Loren - 92 traps is pretty damn good for a stock car.. my car was trapping at 87 and 88 stock..
whats up with all these cali brothers using "corrected times" .. or is it a west coast thing? because Kirk is running around saying his 95 Auto runs 14.8 "corrected"
can we just use whas on the time slip?
Old Oct 25, 2001 | 04:42 AM
  #44
Washington DC Maxima's Avatar
Wow
.9, huh? LOL!!
Originally posted by SprintMax
and another reason why i won't sanction this expense..
I spent $100 on a CAI and $350 on a y pipe.. thats $450
and i was able to cut off .9 secs off my 1/4 mile time.. so .3 ain't sheet..
i then spent $375 on a NOS kit.. but we won't work that one out
Old Oct 25, 2001 | 04:48 AM
  #45
I agree with this whole heartedly
[QUOTE]Originally posted by BrianV
Here's my honest opinion about the ECU. It has no affect on the car what-so-ever at 3200 RPM or below. Right at 3200-3300 RPM the engine opens up, but it doesn't have much of an affect after 5000-5500 RPM. When drag racing you spend most of your time at 5000+ RPM, so the gains in drag racing are minimal. The real gains are evident when you're cruising on the FWY at 90+ MPH and you goto pass a car in 5th gear. 5th gear pulls like 4th gear would on a non-chipped car. The amount of midrange power and torque is a night and day difference. In that specific range the ECU puts down more power than the YPipe did when I got it. However, the Ypipe greatly increases power up top as well, I feel the engine does not benefit from the ECU at above 5000 RPM or so.
Old Oct 25, 2001 | 04:52 AM
  #46
LOL!!
Where's the corrected time link? I should be runnin' 14.8's corrected too since I've run 15.4's and 15.3's in my Auto..
Old Oct 25, 2001 | 05:41 AM
  #47
Sprint's Avatar
Re: LOL!!
with or without chromies?
Old Oct 25, 2001 | 06:28 AM
  #48
Re: Re: LOL!!
Without... 15.6's and 15.7's with..
Old Oct 25, 2001 | 06:59 AM
  #49
MardiGrasMax's Avatar
Corrected times...
I might be a 12 second max then... NOT!!!
I agree with Dave B, please post your uncorrected times and/or note when the times you post are corrected.
Old Oct 25, 2001 | 07:00 AM
  #50
Sprint's Avatar
Originally posted by MardiGrasMax
Corrected times...
post *****
Old Oct 25, 2001 | 07:02 AM
  #51
Sonic's Avatar
Re: Gforce ECU *TRACK PROVEN* 14.3 NA 5speed!
Originally posted by Chebosto
BrianV ran a 14.3 corrected quartermile this past weekend...
his setup: PR/SI hybrid intake, ypipe, greddy, rt cat, and..
modified 96 ECU with Gforce Engineering ECU upgrade (my old ecu i let brianv borrow)
his previous times were 14.6s..
well. brian did it! what a little traction can do wonders..
--cheston
Corrected times mean very little to most people, not a flame, just a statement. BTW, if you want to argue it, 1/3there2/3rdstogo can run 14.8s with his auto NA.
Old Oct 25, 2001 | 07:03 AM
  #52
sx7r's Avatar
post *****
post *****
Old Oct 25, 2001 | 07:05 AM
  #53
Sprint's Avatar
Originally posted by sx7r
post *****
torqueless retard :retard:
Old Oct 25, 2001 | 07:13 AM
  #54
sx7r's Avatar
don't rub it in
  #55
Sonic's Avatar
So are we ever going to get someone to run this test of the ECU, THE RIGHT WAY?
Old Oct 25, 2001 | 09:17 AM
  #56
1MAX2NV's Avatar
Didn't you guys hear what Brian said "We did that at Carlsbad, ran a 15.4 and then a 15.1 one run after another." It's .3 sec difference regardless if it's corrected or non corrected.
Old Oct 25, 2001 | 12:26 PM
  #57
buss95max's Avatar
dont compare the cali peeps to 1/23gottob1/3(whatever)
im outraged
cali barely got a decent track "cali speedway"
too bad it was only open for 3 weeks...its gonna be closed
till january...
Old Oct 25, 2001 | 12:42 PM
  #58
Who has the corrected 1/4
calcualtor??? Where's the link??
Old Oct 25, 2001 | 12:49 PM
  #59
Sonic's Avatar
In other words he ran a 15.1 @ 1/2 mile and whatever temp and humidity and NOT a 14.3 'corrected'.
Old Oct 25, 2001 | 01:17 PM
  #60
Nismo87SE's Avatar
Damn if he runs a 1/2 mile 2640ft in 15.1 seconds then he has a fast *** car. I agree corrected times should be noted and probably not used at all.
Old Oct 25, 2001 | 01:18 PM
  #61
Tri-lite's Avatar
Originally posted by theblue
sprint - most people (even the bad drivers) can pull a 15.2 out of a stock 5spd. Are you trying to tell us that it's the mods that gave you all of that .9 - I don't think so
thats true cuz im stock and I pulled 15.3 with a 1.3 R/T ....3 times...
Old Oct 25, 2001 | 01:21 PM
  #62
Sonic's Avatar
In other words he ran a 15.1 @ ? in the 1/4 mile and whatever temp and humidity and NOT a 14.3 'corrected'. {Yes, this was edited...
Old Oct 25, 2001 | 05:16 PM
  #63
NightRider's Avatar
Well, Another member of the .org and I did some of our own testing at the track by swapping ECUs. We used the G-Force ECU as the tester, which I later bought from him. He has a 97' 5-speed, completely stock, except for the ECU. His best time stock (stock ECU) was a 15.6 uncorrected. We then swapped in the G-Force ECU and he immediately ran a 15.3. His times continued to drop down to a 15.1 for the night. (.5 seconds!!) Then came my turn. I have a 96' Auto with nothing but a cone filter. My best time for the night on the stock ECU was a 16.3. (Damn slow) We went and swapped in the G-Force ECU, and ended up having to reset it. (Going from a 97' 5-speed to a 96' auto gets it confused.) I then went and ran a 15.9 with a 15.8 as the best of the night. (again, .5 seconds!!) That was enough proof for me to buy it. I highly recommend it. And no Cheston is not paying me.
Old Oct 25, 2001 | 05:29 PM
  #64
Sprint's Avatar
thats funny 5 people ran with the ECU and ran .2 secs 2mph faster..
Old Oct 26, 2001 | 12:43 AM
  #65
BrianV's Avatar
The ECU will have a larger effect on the 1/4 mile in an auto than a 5spd because with the auto you're racing for a much longer time in the affected power band.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
I<3 A32's
Sep 10, 2015 11:07 AM
