215/55 or 225/50?
Old Oct 25, 2001 | 12:22 PM
Ben4bamaMax's Avatar
215/55 or 225/50?
what is pro of 225/50 ? better grip?
what is con of 225/50 ? worse gas mileage? if so, how much worse?
should I just stay stock?
btw, 98 SE getting Kumho 712's. thanks!
getting them from tirerack...any recommendations on reps there and what should I pay for shipping?
Old Oct 25, 2001 | 04:09 PM
97GreenMax's Avatar
I stuck with 215-55 just becuase I did not want to throw of my speedometer.
Old Oct 25, 2001 | 04:21 PM
AndyXXL's Avatar
Re: 215/55 or 225/50?
I run 225/55-16 on SE rims. I'm not sure if there's a noticeable difference in gas mileage though.
Old Oct 25, 2001 | 05:39 PM
Enduro's Avatar
...to add to your list..
215/55 - slighty softer ride than 225/50...stiffer suspension will pronounce this difference.
215/55 - slightly less road noise than 225/50
215/55 - slightly better traction in slippery condition than 225/50
215/55 - slightly less traction in dry condition than 225/50
215/55 - slightly less responsive with initial turn-in than 225/50
...again differences are only SLIGHTLY
Old Oct 25, 2001 | 06:44 PM
iwannabmw's Avatar
Re: Re: 215/55 or 225/50?
All of the above plus the difference in the speedo is only 2%. I also got 28mpg on the last tank with 225's.
If there's an NTB around you, you can go there tell them the Tirerack price and they will match it plus $10/tire and you can get them right there and not have to deal with shipping.
Old Oct 25, 2001 | 07:05 PM
ericdwong's Avatar
I got 225 50 16s and I recommend staying with 215 55 16s. The reason being is that it looks pretty odd with 225 rims buldging off the sides. Ontop of that, the overall diameter is a tad smaller so it looks like your car is jacked up even more. Next time I'm doing 215 55 16.
Old Oct 26, 2001 | 07:06 AM
iwannabmw's Avatar
Jacked up look solved with a set of H&R's
Old Oct 26, 2001 | 07:35 AM
WOW! thanks for the great info!! I have decided to go stock with 215/55 and get the Kumho 712's. I called NTB and they don't carry them but will mount and give lifetime balance and rotation for around $83 which will would cost me a total of about $415. $75 X 4 plus $33 shipping plus $80 mount/bal. OR there is a local shop that has Kumho 712's that he says are Z rated??? Is he mistaken or is there a 712 ZR. Tirerack has WR. His total out the door for tires mount and lifetime balance is $420... This sounds good but not if it is a Z rated quick wearout tire. Heard of a Kumho 712 Z?
maximabest
20
Mar 10, 2003 11:37 AM
Dave B
Apr 19, 2002 05:45 PM
Jr'sMaxima
Dec 21, 2001 11:26 PM
Stealth Interceptor
Jul 18, 2001 11:40 AM
