Quaife: First Impressions
Old Nov 2, 2001 | 06:55 PM
bullseye's Avatar
Just installed Place engine mounts, JWT Stage II Clutch, Stillen aluminum flywheel, and the new Cattman/Quaife ATB Differential. Took the Mighty Maxima for a spin, and... WOW! The Quaife is outstanding. My Maxima chews up curves and spits them out. No tire squalling. No slipping. The car just pulls itself around the curves, and launches itself out the other side. What an amazing transformation.
The mounts work as advertised. No more bunny-hopping. I feel a tad bit more vibration at idle, but it's not excessive. I probably will not notice it after a couple days.
The clutch and flywheel are going to take some getting used to. I'll have to forget about feathery smooth starts for a while, at least until I figure out the new set-up. I got a little chatter on start up. And the shifter feels stiff. But when the clutch grabs, it GRABS. No slipping, thank you very much.
Does the car feel quicker? My butt dyno indicates yes, especially around the twisties! Was it worth it? H*** yes! Now it's time to rape and plunder... Muwahahahaha!
Old Nov 2, 2001 | 08:08 PM
emax02's Avatar
Re: Quaife: First Impressions
Ohh jeez, I really hope you are braking your clutch in and not abusing it. If you push the clutch at all during break in you will get clutch chatter.
Old Nov 2, 2001 | 08:10 PM
Tai Mai Shu's Avatar
Now i got to ask you....Did you do these mods yourself or have a shop do it?
Old Nov 2, 2001 | 10:47 PM
bullseye's Avatar
I'm not abusing the clutch. I plan to take it easy for at least the first 500 miles. With the new clutch, there's not much middle ground. It's either "on" or "off" with it so far. That's why I'm getting a little chatter on start up. I lift-throttle on the up-shifts, and I match-revs on down-shifts. Shifting while I'm underway has not been a problem. I have driven a stick for over 25 years, and I never wore-out a clutch until I started racing... Thank you for your concern!
Did I do it myself? No. I do not have the facilities, tools, know-how, patience, nor TIME to have done-it-myself on this project. My hobby as it relates to the car is centered more on driving at this point than turning wrenches. But I'm learning and gaining confidence as I go. My car is in great mechanical condition, and I keep it well-maintained. I have learned a lot from my mechanic, friends, and especially the folks on this forum. Thanks for all your input.
Old Nov 2, 2001 | 11:37 PM
emax02's Avatar
Cool, I just wanted to make sure, I have learned the hard way to many times.
Old Nov 3, 2001 | 05:00 AM
bullseye's Avatar
Thanks again. Let us know how you like the new 6-speed, OK? What color are you getting? Accessories? Does it have the helical LSD?
Take care.
Old Nov 3, 2001 | 05:24 AM
nismo2020's Avatar
Needs non-Maxima Friends
i didnt know jwt made a clutch for our cars. whats the tourqe rating on it?
Old Nov 3, 2001 | 05:34 AM
bullseye's Avatar
Re: Re: Quaife: First Impressions
Sorry, I don't recall. I got it from Cattman Performance at [URL=http://cattman.com] if you wish to follow-up. Or JWT would know, of course. I bet there is someone out there reading this who knows what the exact torque rating is, and may post it soon...
James92SE
142
Jan 2, 2024 09:23 AM
mclasser
22
Nov 12, 2020 01:58 PM
Dasmith
Sep 23, 2015 08:28 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
