Oh crap. The car fell off the jack and something isn't right
Old Jan 5, 2009 | 11:38 PM
DOM's Avatar
DOM
My tire was flat in my driveway so my brother in law and I were going to jack up my Maxima, take my old tire off (Had to return the tire to Costco under warranty. Spare was on other tire that blew out a few days ago), and get my new tire. The jack that came with the Maxima was missing so he used the one off his Titan truck.
When he were trying to put the tire on while I was getting water, the jack slipped and the car fell. Today, I drove to work and when I get above 45, it sounds like my tire is flat. The way my car drives isn't affected at all either but I do hear that sound. Thump, thump, thump, thump, thump.
So I am assuming that something is off and needs to get fixed. So based on what I said, what could be wrong and how much would it cost to fix? Is this a problem that will get worse? Can I just ignore it?
Old Jan 6, 2009 | 03:16 AM
T Keck's Avatar
what did it land on? might have messed up your rotor
Old Jan 6, 2009 | 06:30 AM
njmaxseltd's Avatar
My vote goes to a bad tire. Seems like you have a history with that.
Old Jan 6, 2009 | 12:44 PM
sicivic89's Avatar
Where was the jack positioned? I would say its probably tire related. Spare tires can be a bit loud especially if its tire pressure is low.
Old Jan 6, 2009 | 01:00 PM
Double0Max's Avatar
you may have messed up your hub and bearings
Old Jan 6, 2009 | 01:04 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i say if its a whomp whomp whomp whomp whomp sound its your hub/bearings. I just fixed this a few weeks ago.
Old Jan 6, 2009 | 01:13 PM
sicivic89's Avatar
Did the car fall onto the brake rotor?
Old Jan 6, 2009 | 01:29 PM
rroderiques77's Avatar
Demodded and Forgotten
You ****ed something up...
Old Jan 6, 2009 | 03:06 PM
pmohr's Avatar
No more Maximas...
Yes, ignore it
For one, this is exactly why you use jack stands after you jack it up, not relying solely on the POS emergency jack. Read, emergency.
What did you have it jacked up by? How did it manage to 'slip'?
What exactly did the car fall on to? Onto the jack? On the rotor? If the rotor, then there's your problem.
Have you actually looked at it, or are you hoping for a blind guess from the org?
Old Jan 6, 2009 | 04:31 PM
tav303's Avatar
Originally Posted by pmohr
Yes, ignore it
Old Jan 6, 2009 | 05:17 PM
Matt93SE's Avatar
STFU n00b!
If you have two flat tires in a couple weeks, it's likely the others are bad too. examine/replace ALL of them before you finish this.
Old Jan 6, 2009 | 05:33 PM
gringoinmiami16's Avatar
+1
Old Jan 6, 2009 | 05:38 PM
vqmaxman's Avatar
The first question comes in to my mind,Is what part of your car was on the jack. When the car fell did It hit the jack or It fell and It hit the rotors and the LCA. When the car fell did It also bent the fender and the frame,check It out really carefully and post a pic.
Old Jan 7, 2009 | 08:57 AM
nissandrvr98's Avatar
this is an example of why theres a lot to be said about purchasing a medium duty 2 ton small floor jack that will sit nicely in the trunk-$25 at most will do the trick. Good luck finding what may be broken.
Old Jan 7, 2009 | 09:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
guys...he was changing his tire. so most likely it hit the splash shield and that got dented into the rotor. the noise is the rotor (slight run out) hitting the splash shield. bend the splash shield back and it "should" be ok.
Old Jan 7, 2009 | 10:33 AM
J RO 9's Avatar
are your lug nuts tight?
Old Jan 7, 2009 | 03:05 PM
The splash shield makes a tin-like sound when hitting the rotor as the car rolls down the road. He is hearing something else.
Old Jan 7, 2009 | 07:53 PM
trand71's Avatar
For future reference next time you have a flat, place the spare tire under the car when your jacking it up, take off the flat, place that tire where the spare was, so in case it happens again the car falls on the tire and not the ground. 'Cause i bet it was a &itch trying to get the fallen jack out from under the car, and jacking it back up again. Might want to check that jack as well, that happened to me one time and the jack was literally bent sideways from when the car fell on it. I learned that trick from someone else, and have done that ever since. Good luck in finding what you broke.
Old Jan 7, 2009 | 11:05 PM
dewd's Avatar
oh wow thats messed up man.
might actually be another bad tire
Old Jan 8, 2009 | 08:00 AM
StnBluPearlMax's Avatar
Also make sure if you're going to jack up the car in any circumstances that you're on a flat surface. Seems you said you jacked it up in the driveway which are often an uphill slope which can always lead to bad things!!
My thoughts are that the wheel bearing may be shot. It makes that sort of muffled "whub whub whub" sound when there's one needing replacement.
Best bet? Have someone take a look at it/drive it who knows what they're doing. What we think you're hearing could be totally different than what you're actually hearing.
Old Jan 9, 2009 | 09:29 PM
krzymax's Avatar
Maxima owner since 2000
your flux capacitor is broken.
Old Jan 10, 2009 | 02:33 AM
T Keck's Avatar
I wonder how many people will get this
Old Jan 10, 2009 | 03:11 AM
omartopsecret's Avatar
did you check on the back of you rotor to see if that metal plate is hitting on your rotor, i forget what its called. maybe when the car fell the metal plate bended and that's way its making that noise.
Old Jan 16, 2009 | 10:56 AM
mtalley82's Avatar
Everyone who didn't grow up in a barn.
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
N2deep
Aug 16, 2015 08:30 PM
MikesChevelle
Aug 9, 2015 11:50 AM
