which car did this vq35 engine come from?
Old May 8, 2009 | 11:20 AM
PlanoSER's Avatar
I have a 2002 maxima 6spd. I've replaced the transmission in the past with a 6th gen non hlsd trans when my third gear went out. It was no problem, just swapped the shifter linkage brackets and it bolted up. I ran the VIN plate on the transmission and know it came from a 2004 maxima.
Now, i need to replace the engine (bad ticking from shim bucket to cam clearance too high, 120k miles, etc....)
So i found an add on craigslist for a vq35de engine. It was listed as a 2004 maxima engine with 21k miles being sold from a local salvage yard. There wasn't any info about the motor (no vin or car to be found), but I took the valve covers off and it was clean and looked exactly like my current engine. Bought it, brought it home. I figured, I have a 6th gen trans, a 6th gen motor should work as well.
So after removing my old engine and installing the new one, Im down to the very last part of connecting / swapping sensors. The problem I'm having is the Crankshaft Posistion Sensor hole on the new engine does not match the 6th gen transmission. Did they sell me a different year motor or one from a different model that uses a vq35?
The sensor hole on the engine is at 6 oclock and on the transmission (and my old engine) it is located at 3 oclock (facing radiator).
First image is at 6 oclock:
Second image is at 3 oclock:
Engine:
Old May 8, 2009 | 11:30 AM
Kevlo911's Avatar
Kevlo for President
WTF??? That is extremely odd. The vin stamp is no longer on the engine?
Old May 8, 2009 | 11:38 AM
PlanoSER's Avatar
Engine's dont come with the car VIN stamp on them, they only have engine serial numbers.
The transmission does have VIN plate on them.
Old May 8, 2009 | 11:40 AM
Kevlo911's Avatar
Kevlo for President
Doh that's right.
Sorry for my n00bness but can't you just swap the oil pans?
Old May 8, 2009 | 11:45 AM
PlanoSER's Avatar
Doh that's right.
haha, wow, i feel dumb. I didnt think of that yet. I will have to check to make sure that will work. From the picture it looked like swapping the upper oil pan would do the trick. Thank you.
I was going to redrill/extend the whole for the CPS and tap a new thread hole to bolt it in, but that was my last resort answer.
Old May 8, 2009 | 11:55 AM
Kevlo911's Avatar
Kevlo for President
Yeah, the pans will swap for sure, I just couldn't remember if the sensor bolted to the block or the pan
Old May 8, 2009 | 01:59 PM
ajcool2's Avatar
The engine most likely came from a nissan quest. Ghostmax301 just swapped one in his 4th gen and he said the only difference was the location of the CPS.
Old May 8, 2009 | 03:39 PM
PlanoSER's Avatar
Interesting. Thanks for all the info guys. I notice the Quest has a lower HP/TQ rating; if this truly is a Quest motor, is that anything to be concerned w/ as far as losing any performance from this swap?
Also, I wonder if I can decode the Engine Serial# to figure out what I really got? Been searching for info on that but not finding much info
Old May 11, 2009 | 07:21 AM
njmaxseltd's Avatar
Nope, your trans gearing and your ECU will make the HP/TQ rating the same.
Old May 11, 2009 | 09:32 AM
PulsarGTS's Avatar
Engines are rated to the flywheel so why would the trans have any effect. They all put out 240bhp anyway.
Old May 11, 2009 | 03:25 PM
PlanoSER's Avatar
Well guys, I swapped the upper oil pan and it worked like a charm -- she was a little tight at first when I tried to turn the crank w/ wrench, but she loosened up then I primed the lines and fired her up -- she purrRrs! Sounds great and feels very smooth. I need to p/u a new idler pulley after work and change the oil then I will open her up a bit to see how she really runs
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 9, 2015 02:48 PM
