how often to change gear oil
Old Jan 15, 2002 | 05:30 AM
jadismi
Guys - New (95)Maxima owner, and my first 5 speed.
How often do I need to change my gear oil? Ballpark, what should this cost?
The last time I had it changed they replaced something called the neutral switch... uh what's that?
If this makes any difference, I'm pretty easy on the clutch.... I miss a gear and grind it a bit once a week. Thanks for your help, great site.
Old Jan 15, 2002 | 05:58 AM
iwannabmw's Avatar
Re: how often to change gear oil
How did this end up getting posted twice on diferent days
Old Jan 15, 2002 | 06:09 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Go ahead and change it.
Instructions on how:
http://forums.maxima.org/showthread....threadid=45742
Old Jan 15, 2002 | 06:33 AM
Blackgums100's Avatar
Not to break *****, but if you are grinding your gears once a week you are not easy on it. When I miss a shift(rarely) especially during a hard shift it makes me want to cry.
Old Jan 15, 2002 | 08:33 AM
ericdwong's Avatar
Neutral switch is that black round unit at the bottom of the tranny. These are notorious for springing leaks in them. When you do change the tranny fluid, carefully examine the condition of the fluid especially looking for silvery shavings and check the seales around the CV axles for leaks. Be very careful of worn bearings.
Old Jan 16, 2002 | 09:10 AM
young1976's Avatar
just make sure you don't use the wrong type of gear oil.. API GL-4 I think is what you need.. And don't get the multigrade stuff either... 75w-90 is what you would need ie... Redline MT-90 expensive but good synthetic. Other grades will destroy your synchros over time..ie GL-5
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
