How do I got about cleaning carbon out of my intake manifold?
Old Jan 17, 2002 | 02:12 PM
BriGuyMax's Avatar
I'm suspecting a large build-up of carbon in my intake manifold...and i want to clean it out...what do you guys think is the best method of doing this???
Old Jan 17, 2002 | 02:16 PM
mzmtg's Avatar
Minister of Silly Walks
I took mine off and sprayed a whole bunch of cleaner through it.
Old Jan 17, 2002 | 02:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
the manifold on:
spray TB cleaner...run engine
OR
do that top engine cleaner thing where u dip a vacume hose into the cleaning solution..etc etc
the manifold off the engine:
simple green or castrol super clean
use a wire brush
best is to do it w/ the manifold off the engine.
Old Jan 17, 2002 | 03:16 PM
BriGuyMax's Avatar
thanks for the input guys...I think I found an easy way to clean it a little bit at least...I just pulled my PCV valve out of my valve cover..still attached to the little hose...and it was really oily and sooty..so I took it off the hose and sprayed it with TB cleaner and got all the gunk out of it...I then re-inserted it into the hose and turned on my engine...I had my friend rev my engine to two grand...and I sprayed TB cleaner through the PCV valve until the can of TB cleaner was gone. I'll have to go take it on a test run to see how it worked.
Old Jan 17, 2002 | 05:36 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
get a wet NOS kit that will lean out all that gunk.
Old Jan 17, 2002 | 05:52 PM
Sprint's Avatar
Brian you want your top end back?
sell your UDP
Old Jan 18, 2002 | 12:40 AM
BriGuyMax's Avatar
sell your UDP
d@mn you!
oh, I'll get my top end back...as soon as I clean my darn manifold all the way...
Old Jan 18, 2002 | 08:30 AM
MAX2000JP's Avatar
Originally posted by BriGuyMax
d@mn you!
You need your top end AND low end back, so automagics dont pull on you from a standstill
Old Jan 18, 2002 | 08:36 AM
Nealoc187's Avatar
SLOW
OUCH
Old Jan 18, 2002 | 08:40 AM
MAX2000JP's Avatar
Originally posted by Nealoc187
OUCH
Neal are Brian or you ever gonna post any of the videos that you made? Does he still have the videos that we taped on the way to the track and at the track? We need to post these to represent the mid-west
Old Jan 18, 2002 | 08:53 AM
Synki's Avatar
Bri, maybe this thread will give you some more info.
http://forums.maxima.org/showthread....5&goto=newpost
I usuaully just spray a full can into my TB but if you check that thread out, there is a better way. You will also clean out teh EGR valve and prevent any problems down the road.
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
seesole
Sep 14, 2015 12:38 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
Maxboy23
Sep 9, 2015 10:37 AM
