K&N filters
Old Jan 24, 2002 | 01:56 PM
Kevlo911's Avatar
Kevlo for President
K&N filters
i have a genaric 3" cone filter i washed it the other day and the color did not go away... on the kn recharger kit it says it will turn white and when u spray the red oild on it it will be red again and mine did not turn white.....is it ok that i washed and reused it or do i need to change it
Old Jan 24, 2002 | 05:11 PM
theMax's Avatar
Re: K&N filters
the old oil did not come off. did you use the K&N cleaner to remove the oil?
Old Jan 24, 2002 | 06:30 PM
djmaxski's Avatar
As long as it's not torn or anything, it should be fine. I assume when you mean washing you used the cleaning solution that comes in the K&N Recharger kit? That should turn the filter white, and then when you re-oil it you should see it turn red where the oil is. Its ok to get it wet, if that's what you are asking... After using the cleaner you should rinse it, let it air dry, and then re-oil and then install it.
Old Jan 24, 2002 | 07:49 PM
nismomaxse97's Avatar
Re: K&N filters
Hey Kevlo,
What part number is the 3" cone filter for K&N.
Thanks in advance
Brett
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
