sub frame review
sub frame review
well just had the sub frames put in. went to arkanas to see Dallas at WSP. well he took care of me, did stage 1 and stage 2 sub frames. they even added more braces to the original for me. most of the parts where custom made to give my car more ground clearance. after it was finished i had plenty of ground clearance. took the car for a test drive and the difference is noticeable right away. mostly all of the body roll is eliminated. the bouncing affect after hitting a bump in the road is gone. the car hits the bump and come right down to the ground. around turns the car stay nicely stuck to the ground. quick turning and cornering is a lot easier and the car does not lift but you better hold on to the wheel. you turn hard enough and the it will try to put you in the passenger seat. overall, i am very impressed with the results. they are the only ones that offer this upgrade and it isn't that expensive either. last thing, i also had them built me a new exhaust system for my are. it came out great. it still is a bit loud but thati s the way it was before. the put in there new y-pipe and a hi-flow cat, both 2.5 in. also i believe that i now am the only one with a mandrel bend exhaust system that is 3.0 in. may full cat back is 3.0 in. there is defenitely a difference in power. i can not get the car to stop spinning the wheels. it spins all the way through 1st and into 2nd. well either of the products are worth it. i drove from Chicago to get this done and i am glad i did. well give Dallas a call if your interested. also i will try to post pics. peace.
Re: sub frame review
DPW
REDinLV
Aug 15, 2024 12:30 AM
rbaker100
Sep 25, 2015 07:52 PM
Hdnseek
Sep 9, 2015 05:55 AM
