Vq40 throttle body and maf on my vq30
Old Nov 30, 2015 | 04:50 AM
teejay1786's Avatar
I was wondering if this works and if so what all do I need just the throttle body and maf sensor?
Old Nov 30, 2015 | 04:52 AM
teejay1786's Avatar
This article says you can use a Nissan Frontier throttle body and maf sensor from the vq40 and slap it on your vq30 is this true??
Old Nov 30, 2015 | 10:48 AM
Cotozic's Avatar
I know some guys used the 01/02 Pathfinder TB on the 4th gens with 3.0s. This will give some good gains - but I do know that swapping a TB isn't just as simple as it sounds. On the 3.5 in my 02, I swapped to a 75mm TB and it required that I readjust the IACV with an OBD2. I also know swapping a MAF on the 3.5 requires a tune if you swap in larger. Not sure about the 3.0.
http://autoresource.internetautoguid...icks-2042.html
I read the rest of this article. I wouldn't say his claims are all that great.
Old Nov 30, 2015 | 04:40 PM
teejay1786's Avatar
Ok thx for the info.
Old Dec 1, 2015 | 08:41 AM
NmexMAX's Avatar
dot dot dot ...
Sounds like a croc to me.
VQ40’s are TBW, VQ30’s aren’t, that would be doable by converting the TB to be cable driven. The MAF would also require some extensive programming. Easier just to bore an OEM unit or build your own larger diameter unit and use a MAF scaler like an SAFC to do that.
Also, all we have is the crank pulley, all the others (UDP set) don't take up much power and no one actually has made a "Set" just the UDP for the crank.
Old Dec 4, 2015 | 09:56 AM
teejay1786's Avatar
Ok so bare with me I'm kinda slow lol! So like Coto says I can use a 01 or 02 pathfinder maf and throttle body on my vq30 for gains if I was to do this can you give me the link to the thread on how to do it please and thank you 😄
Old Dec 8, 2015 | 03:11 PM
NmexMAX's Avatar
dot dot dot ...
Someone was making PFTB adapter plates not too long ago since Stephenmax stopped doing so. Check the AM forum, lotsa info in there I'm sure.
https://maxima.org/forums/4th-genera...-write-up.html
Old Dec 22, 2015 | 08:02 AM
teejay1786's Avatar
Ok so one thing I don't understand about the pathfinder tb write up is he says he flipped around his tips sensor and he said all this stuff about repositioning the tps a lot but never explains needing to set the tps after messing with it really the tps should never be moved not even a millimeter cause if it moves that much it needs readjusted when I barley touched mine I had to take the car to a mechanic to adjust it because it was to hard with my multimeter and I'm pretty savvy with cars it'll make your car shift all messed up and these cars have really really touchy tps sensors
Old Dec 22, 2015 | 08:06 AM
teejay1786's Avatar
Also I don't understand how he could have flipped it 180 it's literally a spring with a little metal flap that pushes the spring for the tb electronically it only goes one way if it was flipped it wouldn't catch the spring and it would try to open the flap on the tb the other way which would not work the throttle body only opens one way lol
Old Dec 22, 2015 | 05:07 PM
schmellyfart's Avatar
The throttle blade has two shafts that can turn the TPS. So yes you can spin the TPS around 180* and have it still work, as I have done so on both my 00vi and 3.5 swaps when I was using a Pathfinder TB.
Old Dec 23, 2015 | 03:19 PM
teejay1786's Avatar
oh? Ok my bad lol well thank you guys so much for all the info after looking for over two years on ways to tune my vq30de-k I realize that it may literally be easier for me to just buy a ls Chevy motor throw it in have my buddy fab and weld up a drive shaft housing well and link it all up lol I wonder if that's at all possible for under 7k I'm just hating the garage mechanic mods and headaches ls FTW! Lol don't get it twisted though I want my maxima forever!!!!
Old Dec 26, 2015 | 06:40 AM
Quickywd01's Avatar
People won't spoon you info here. Even when knowledgeable people come here to ask questions they get treated like idiots. If you can't spend the time to read the info about these mods then it isn't worth it for you. But if you do put in the time, you can get power out if it. Once you open up the intake and exhaust you need to rev it higher to get the "most" out of it. 2000-2001 maxima 3.0 vq30De-k variable intake manifold aka the black plastic one. Headers, ypipe, 3" catback. Biggest filter you can fit on the maf. Then some way to control the chAnges you've made; emu etc. Here's some inspiration
Old Feb 17, 2016 | 02:25 PM
teejay1786's Avatar
I already have the black intake manifold mine is a 2001
Old Feb 18, 2016 | 07:12 AM
NmexMAX's Avatar
dot dot dot ...
How about all that other stuff he mentioned?
james_costanza
Dec 3, 2015 07:56 PM
kingkai1990
Nov 30, 2015 06:20 AM
kingkai1990
Nov 21, 2015 04:52 PM
jchronis2552
Nov 14, 2015 05:51 PM
