How to find E85 ethanol gas stations?
Old May 6, 2016 | 12:34 PM
shadyonedeath's Avatar
I know most g's now has ethanol, but are there any thy provide JUST e85? Or am I missing something.
Trying to find e85 to pass smog in CA...if I can't find it, I'll try denatured alcohol.
Old May 8, 2016 | 09:51 AM
DennisMik's Avatar
The reason you can't find the E85 fuel is because ethanol is a poor excuse for a fuel. It only has about 75% of the energy that petroleum gasoline has. The car's performance will suffer dramatically. The fuel economy will also suffer by about 25% as well.
All this was shown time after time 10+ years ago when the dual Flex fuel cars were around. And now the government is pushing them again. As another point against ethanol, it requires more energy to refine ethanol than ethanol produces. Add to that, it creates shortages in corn supplies, thereby raising food prices.
Old May 8, 2016 | 11:17 AM
MadMax SE's Avatar
Under atmosperic pressure ethanol fuel has less energy then gas. For economic use, e85 doesn't have the best gas mileage. What it does have is the ability to resist knock up to 1000hp non intercooled (will link threads later), chemically cools the combustion chamber, and cleans carbon exceptionally well. To the average consumer(you) it is a poor choice of fuel, for a vehicle entuaiast its a chance to run rediculious boost/compression/timing on the streets for way cheaper than race gas. It has the equivelient of up to 105 octane.
The tests the government does with e85 is done on a GASOLINE engine and not a e85 only engine so they are useless anyway. If we built a motor to specificly use e85 to it's highest potential, we could have 1 litre motors pushing 12-1 compression and boost ontop of that.
Old May 8, 2016 | 11:21 AM
MadMax SE's Avatar
I'm not sure if you guys have one over there but Valero has e85 pumps, otherwise I would look into ordering it by the barrel for the occasional use or inspection in this case. I mean, if they sell straight ethanol I don't see why you could mix your own. It would just require alot of alcohol.
Old May 8, 2016 | 12:06 PM
dcpatters's Avatar
OP, is the Maxima E85 compliant?
Nevertheless, here you go.
http://www.e85vehicles.com/e85-stati...alifornia.html
Old May 9, 2016 | 10:38 AM
No but thanks for the responses. Replaced my cat and passed.
Binford
May 10, 2017 01:14 PM
Nissanonator
May 13, 2016 01:05 PM
hithesh
Apr 30, 2016 11:28 AM
Max.C
Apr 22, 2016 07:20 PM
SquidBeak
Apr 15, 2016 06:04 PM
