The Beginning Of A Much Needed "Revival!"
Old Mar 19, 2019 | 09:24 AM
Scottees96M's Avatar
Scottee P with you from the Maxima scene from the 303! Getting ready to toss these boys in and give the Max a good ol "revival" tune up! I like to stick with the NGK's! Will update through out the progression! Until then, 4th Gen Squad! 👊
Old Mar 19, 2019 | 09:48 AM
Turbobink's Avatar
Originally Posted by Scottees96M
... Maxima scene from the 303 ...
Once again, I don't know what this means.
Old Mar 19, 2019 | 09:54 AM
Pretty much saying from the Maxima owners in Colorado.
Old Mar 19, 2019 | 10:01 AM
Turbobink's Avatar
Ahh ... so "the 303" is your area code ...
Old Mar 19, 2019 | 08:19 PM
vqmaxman's Avatar
Welcome to the org. Hope you like it here and the stickies here on the on the threads and all the much needed info is in the 4th gen section. Hopefully everything goes well on reviving the max and getting it to run as it should. Good luck.
Old Mar 19, 2019 | 08:24 PM
Not what I wanted to see but plugs are successfully changed. .!..
Found this guy the second plug into the shacha.. There's a $60 hiccup in my project for the day..
Old Mar 21, 2019 | 06:28 PM
chongher's Avatar
Wow I've never seen anything that bad. Good thing you caught if before it caused more damage to the engine. And welcome to the site from a local fellow.
Old Mar 22, 2019 | 09:03 PM
FanaticMadMax's Avatar
Wow that spark plug is literally would fall in cylinder and damaged the valve and piston and the coil pack is expected since the plastic can age and become brittle to break
Arick240
Apr 25, 2017 09:48 PM
Big_E-Dog
Sep 23, 2008 12:25 AM
clint240sx
23
May 8, 2008 06:38 PM
ethnic6
24
May 30, 2006 08:28 PM
