Hooking up sub Need info on RCA cables
Old Nov 14, 2000 | 05:19 PM
Mzark
Ive never hooked up a sub before and i just got done doing it. The amp turns on fine but the i didnt hook the sub up correctly. The RCA cable inputs on the sub are this screw type and the cables dont fit direct in they're too small. If you unscrew it enough there are sideways holes in the inputs if you know what im talking about. Can anyone help me hook it up correctly.Also how can you tell what hookup is what on the sub, whether it is + or - ? The box i have is really hard to see the connections. Thanks
Old Nov 14, 2000 | 05:47 PM
Chunger's Avatar
My other car is a Hybrid
Kinda confusing...
First off... is you sub box amplified or not.
Amplified ones take RCA imput(s) (and sometimes also have speaker connectors) and have hookups for 12V and Ground and Remote.
An nonamplified sub box only has speakerwire connectors... then you need an amplifier and connect the two (box and amp) using speaker wire.
I won't get into crossovers/parallel/series etc...
If this didn't help then please post more info on your equipment...
Old Nov 14, 2000 | 08:26 PM
GarthG's Avatar
The RCA cables don't go directly to the sub, they goto the amp. To connect the speaker, you run speaker wire from the amp to the sub. There shoud be RCA plugs and a place to hook up speaker wire also on the amp. the speaker wire fits into the screw posts.
Old Nov 14, 2000 | 08:34 PM
97GLES's Avatar
adidas-boy is right, rca to the amp and speaker wires to the subs.
gigabyte
Jan 6, 2017 06:05 PM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
