Help and advice needed please.
Old Dec 31, 2019 | 07:56 PM
roy1968's Avatar
I brought a 2007 nissan Maxima SE with 148,000 miles on it. I went to atlanta to test it out and notice it burned more gas than normal and the power wasn't all there. So i had surgery and wasn't able to get a knowable mechanic to check it out before the warranty expired. Check light came on took it the auto zone and codes P0300/ P0102/ P0113/ and # 4 cylinder was misfiring. Car started to stuttering real bad and running very rough here and there.. I got extended coverage so I had it towed to nissan. 280.00 for them to tell me i needed a tuneup and rear brakes which it knew and 2000 just for the tune up that I would need do at a dealership. I got a guy to tune it up with plugs and just #4 coil and I didn't get all 6 because i didn't have the funds. So I notice the rpm would drop very low at a stand still and go back to normal. I put an MFS on it and it ran good for a little bit but again the rpm was dropping again. I'm over 1000 dollars in and problem not fixed. Codes P/0300 P0300/ P0174 was detected. I decided to change the air filer and notice that it was upside down all this time. I just knew that was the problem all the time. The light went off after I put the filter in correctly. Ran good for a little bit and rpm started dropping again. I also got the sputtering and rough idling again but it would go away. Any help would be gladly appreciated. Also if anyone know a knowable mechanic in or around Raleigh NC and surrounding areas please let me know. Happy New Year to everyone and your families. God Bless.
Old Jan 2, 2020 | 08:31 AM
TallTom's Avatar
The cars are sensitive to the quality of the coils installed. If the mechanic put in a cheap chinese one, it's pretty much garbage. Replace with a Hitachi brand or one from a dealer.
Old Jan 25, 2020 | 10:30 PM
roy1968's Avatar
TallTom thanks for your reply.
Old Jan 25, 2020 | 10:31 PM
roy1968's Avatar
Old Jan 26, 2020 | 12:52 PM
Please don't double post threads on the forum. Use your other one in the 6th gen forum.
roy1968
Jan 28, 2020 08:40 PM
El_BoriMax
19
Nov 21, 2012 07:38 PM
96blkonblkse
Apr 27, 2006 12:43 PM
jimkim2004
Jan 26, 2004 07:17 PM
Balthazar
Jan 3, 2004 11:15 PM
