NOS Bottle mounting options
Old Feb 15, 2002 | 07:56 AM
ejj's Avatar
ejj
So, I'm going to start the install of the kit shortly. How do you guys recommend mounting the bottle?
Drilling into the body of the car itself and putting holes in the trunk liner? Placing a sheet of plywood (or something similar) in the trunk and drill into that?
What have you guys done?
Old Feb 15, 2002 | 07:59 AM
Synki's Avatar
I would use a piece of wood & mount it to that. I drilled right into my body & recently sold the nitrous kit. You can see right through the holes & see thr ground. I mounted mine on the driver side. I knpw sprint & sx7r mounted it on the same side. 1MAX2NV mounted his on the passenger side. In the trunk, there are the rubber gromets, use a razor blade and slit a little "x" and rnu the hose right down. If you mount on driver side, run the hose next to the fuel line. Just zip tie it to fuel line.
Old Feb 15, 2002 | 08:36 AM
Sprint's Avatar
Old Feb 15, 2002 | 08:38 AM
ejj's Avatar
ejj
Thanks guys...
Where to mount the bottle isn't my question though. I want to know what to mount it on.
sx7r's Avatar
Re: NOS Bottle mounting options
i've done both. i found just drilling into the trunk itself was easiest, most secure, and clean looking.
Old Feb 15, 2002 | 08:49 AM
Sprint's Avatar
Thanks guys...
Old Feb 15, 2002 | 09:14 AM
ejj's Avatar
ejj
Originally posted by SprintMax
Okay...use some words.
What material is that?
Old Feb 15, 2002 | 09:29 AM
VQdriver's Avatar
use a fake duffel bag setup behind your driver seat. run a line up to the engine bay. there you have a "stealthy" setup and you can remove it when you're done. or use 5lb bottles inside your dash. haha this is the cheating way. i don't have nitrous. this was just a suggestion from a certain performance shop employee i was talking to recently(who won many all motor contests using a similar method). i will never go to nos when i can have all motor power! i will run 13s. i will!
Old Feb 15, 2002 | 09:34 AM
SuDZ's Avatar
Re: Re: NOS Bottle mounting options
after removinf NOS did you do anything about the holes?
SuDZ
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
