Need help - Dremel and Polishing
Old Feb 24, 2002 | 02:36 PM
tifosiv122's Avatar
Hi. I just bought the Dremel to polish my Stillen FSTB and Valve cover and stuff. Which "heads" do I need to buy to get the job done.
Thanks,
Erik
Old Feb 24, 2002 | 04:45 PM
Tai Mai Shu Jr.'s Avatar
Re: Need help - Dremel and Polishing
Thanks,
Erik
eehhh I would just use some very fine sandpaper,and water. Leaves more room for error
Old Feb 24, 2002 | 04:47 PM
tifosiv122's Avatar
Re: Re: Need help - Dremel and Polishing
I am what we call very lazy. If I have to use my hands it will never get done.
Erik
Old Feb 24, 2002 | 04:51 PM
ny96max's Avatar
Thanks,
Erik
to be honest Erik, you will never get the FSTB polished using a dremel or sandpaper. Have your bar polished out for like $60-100 like i did. Well worth the $$ and saves you the hassel and frustration of it not coming out 100%. Mine has ZERO imperfections in it and looks like chrome, i even had the brackets powder coated silver.
As for the valve cover sand it down starting with 80grit, then 100 gritt then go, 200,400,600(wet),800(wet),1000(wet),1500(wet),2000 (wet), then polish the $hit out of it using Mothers MAG/Aluminum Polish(small red can $6)any local auto shop sells it
have fun!
Ant
Old Feb 24, 2002 | 05:00 PM
Greg's2kGLE's Avatar
Thanks,
Erik
Erik, I did mine with sandpaper and my two hands. It isn't perfect or the best looking but there is a shine to it. I probably could have done a better job, but with those two screw hole pyramid things on the 5th gen valve covers (for the AE engine cover) it was hard to get in tight places. Just use a low grit sandpaper (coarse) and increase the grit (finer) as you go along and you'll get a nice shine. Then polish it with Mother's Mag/Aluminum Polish. You'll see it at the meet on the 10th.
Old Feb 24, 2002 | 05:39 PM
ny96max's Avatar
i thought i just said the same thing
Old Feb 24, 2002 | 05:46 PM
Re: Re: Re: Need help - Dremel and Polishing
I guess we were writing it at the same time and I didn't see yours.
Old Feb 24, 2002 | 07:34 PM
WizzaMax's Avatar
What helped me was the wire brush attachments for the dremel...especially on the bolt heads and curved spots.
JonBlz
Oct 5, 2015 06:02 PM
dcam0326
Sep 26, 2015 05:20 AM
followthadollar
Sep 23, 2015 08:31 PM
DBear
Sep 14, 2015 08:33 PM
