aarrgg!! help! gum problem.
Old Feb 25, 2002 | 01:03 PM
mb1's Avatar
mb1
I somehow managed to sit in some gum on the train (idiot), and now there is a big wad of gum on my seat. How do I get it off???
Old Feb 25, 2002 | 01:22 PM
SuDZ's Avatar
Re: aarrgg!! help! gum problem.
Carpet cleaner stuff from autozone. Alot of it breaks down stuff like that and get at it with a towel and water too. Water hardens up gum and makes it easier to remove.
SuDZ
Old Feb 25, 2002 | 01:41 PM
Colonel's Avatar
Old Fuddy Duddy
ASSUMING you have cloth seats, take ice and set it on the area and then carefully pick at it with like a spatula or putty knife (same similiar shape) I would try this first as you start putting chemicals and stuff on your seats, you will risk fading, deteriation so on and so forth. Good luck, gum is a PITA to get out/off of anything!
Old Feb 25, 2002 | 02:06 PM
mb1's Avatar
mb1
Thanks for the help guys. I searched online, and found that vinegar apparently removes gum. I tried it, and it worked like a charm. So if anyone has a similar problem, use white vinegar.
Old Feb 25, 2002 | 03:09 PM
Kevin Wong's Avatar
wd-40 works well too. Just spray a little bit on a paper towel or napkin. Rub it into the gum and it'll dissolve. Then clean up with a towel with water.
Old Feb 25, 2002 | 04:52 PM
mzmtg's Avatar
Minister of Silly Walks
Peanut butter breaks up gum. But then you have to clean up the PB...
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
markevans999
Sep 10, 2015 04:29 PM
