Foglight problem plz help!!!
Old Feb 26, 2002 | 08:43 PM
juice's Avatar
I turned on my car (2K2) and the fogs aren't going on anymore. I have done the foglight rewire over a month ago and everything was working properly. I have checked all the fuses both inside the car ans under the hood. I have also tried a new relay box. The connections were done with 3m wire taps and they are also fine. All other lights on the vehicle are working properly. I do not know where else check for possible failures so any help will be very useful. Thanks
Old Feb 26, 2002 | 08:44 PM
WizzaMax's Avatar
Use a test light to make certain the lights themselves are getting power then work back thru harness as much as you can. Good luck....
Old Feb 26, 2002 | 08:45 PM
juice's Avatar
Re: Foglight problem plz help!!!
I also tried switching the bulbs and that was not the problem either,
Old Feb 26, 2002 | 09:01 PM
Badaxxima's Avatar
If the power is getting to the bulbs, it might also be the bulb sockets. I'm not an expert though.
Old Feb 26, 2002 | 09:04 PM
iansw's Avatar
ebmorgan and I noticed that if one bulb is bad, both won't work after the rewire.
Don't quite know why. Maybe it was a fluke and we actually did blow both bulbs (although the fillament was bad in one, and not the other)
Anyway, you might just try new bulbs...or buy a voltmeter at Radio Shack for $10.00
IanS
Old Feb 26, 2002 | 10:10 PM
juice's Avatar
bulbs
I switched both and they still wont go on.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
