Tranny Fluid warning! GL-4, NOT GL-5
Old Mar 8, 2002 | 12:02 PM
dwapenyi's Avatar
I noticed that some of you guys have been running Mobil 1 synthetic tranny fluid in your 5 speeds. I just picked some up and was about to use it, but double checked my car manual.
The manual specifies GL-4, 80W90. Mobil Synth (and Castrol Syntec) gear lubes are both GL-5, 75W90. I figured that since the weighting is 75W90 whereas the car requires 80W90, the GL-5 would out-perform the standard gear fluid, right??
Wrong. GL-5 can corrode certain parts of the tranny, like synchros. Here's a VW article as an example;
http://www.concentric.net/~Sxs/Oils.htm
I'm retrning the stuff and going back to Red-line MT-90. It was great before. The only reason I was trying the Mobil stuff was because it was right there on the shelf at my store. Redline matches all our specs and exceeds, 75W90 and GL-4
Word to the wise
DW
Old Mar 8, 2002 | 12:06 PM
PhatGuy
GL-4 = Redline mt-90 and MT
Old Mar 8, 2002 | 03:05 PM
SuDZ's Avatar
Re: Tranny Fluid warning! GL-4, NOT GL-5
Word to the wise
DW
How often are you changing yours? Were you changing it just cause it was old or do you do it routinely?
SuDZ
Old Mar 8, 2002 | 03:32 PM
dwapenyi's Avatar
Re: Re: Tranny Fluid warning! GL-4, NOT GL-5
Dan B Martin, when he was around, corrected me on this. I quoted from the FSM that you never have to change your tranny fluid, which is true, sort of. But, if you tow a trailer or other such activity that loads up your tranny, then change it, I forgot the interval. I assumed that no-one uses their Max to tow. I think on this forum, that would be like 90% of us. Anyways, that's the deal.
I changed mine at 100K miles even though I didn't have to. I just wanted my tranny to last. Damn bearings had to go one me, and I still had a good clutch
DW
SuDZ
Old Mar 8, 2002 | 05:36 PM
iwannabmw's Avatar
While most of us don't have to change the tranny fluid I still like the benefits of switching to a synthetic.
Old Mar 8, 2002 | 07:45 PM
Rutnick's Avatar
Re: Re: Re: Tranny Fluid warning! GL-4, NOT GL-5
DW
I have been gone for sometime but now am back. What happened to Daniel B Martin?
Old Mar 8, 2002 | 09:02 PM
dwapenyi's Avatar
Re: Re: Re: Re: Tranny Fluid warning! GL-4, NOT GL-5
Search for a thread he started. He said he had to go away for a while. Hasn't been back since.
DW
litch
123
Jan 4, 2024 07:01 PM
fx4five
Oct 18, 2015 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
