Just got my Y-pipe installed but theres a problem
Old Mar 13, 2002 | 10:39 AM
klee215's Avatar
sup all
I just got my y- pipe installed and love the extra power i'm getting. But when i start off hard and my wheels start to hop a lil i hear dis banging noise from the pipe. I checked everything out and it all looks secure and tightly in place. Can anybody help its really annoying..
Old Mar 13, 2002 | 10:49 AM
grEDdymax@aol's Avatar
Re: Just got my Y-pipe installed but theres a problem
Originally posted by klee215
sup all
sup kenny hyung,
where did u get it done? i hope u didnt get it done at 2nd/lindley...
i dont know what that sound is, sorrie...
Old Mar 13, 2002 | 10:55 AM
OriginalMadMax's Avatar
sup all
That's what the Place Racing motor mounts will solve, because the engine rocks on the soft stock ones. Check the homemade polyurethane thread (http://forums.maxima.org/showthread.php?threadid=102080) Those don't feel bad, but you have to increase idle about 150-200 rpm. Also, read about the $.02 solution I posted on that same thread. That might be a good quick fix.
Old Mar 13, 2002 | 11:38 AM
Dave B's Avatar
Not DAVEB the parts guy
Let me guess, this is a Cattman pipe? No matter what, NOTHING should be hitting the underside of the car under WOT or under hard shifts. The pipe isn't fitting correctly.
Dave
Old Mar 13, 2002 | 12:13 PM
ejj's Avatar
ejj
Dave
My cattman pipe has never made any noises. I am willing to bet that the installer screwed up.
You can't really mess up the manifolds, so odds are its something with the y->cat connection. There is a bracket that holds the y-pipe up to the car if it is not connected to the cat. The bolts for the cat need to go through this to secure it to the exhaust...otherwise it can flop any which way it would like.
Make sure that support is secured.
Old Mar 13, 2002 | 12:14 PM
DOM's Avatar
DOM
I have the same thing. Someone told me that I should check out www.greghome.com and look under the Y pipe installation section to see what to do. I guess there is some kind of a hangar that needs to be bent up. I haven't checked it out and I have had the pipe for a year now.
Old Mar 13, 2002 | 12:16 PM
DOM's Avatar
DOM
Here it is. Find 4/12/2000, click on it, then choose Y pipe prototype #2. It explains what to do in the third picture and paragraph from the bottom.
Old Mar 13, 2002 | 12:23 PM
ejj's Avatar
ejj
Strange...I've installed a few y-pipes now, and I've never bent that piece and I've never heard a rattle.
I don't think you should have to do this if everything is done correctly.
Old Mar 13, 2002 | 12:34 PM
VeeTec's Avatar
Some of the Cattmans don't fit perfect. A little modification of your undercarriage may be needed. Or send it back to Cattman and request another unit.
Old Mar 13, 2002 | 01:09 PM
breaux124's Avatar
I had the same issue with my WSP Y-pipe. Just bend the bracket around the Y-pipe/Cat section and it should fix the problem.
Warpspeed even mentions it on their website:
http://www.warpspeedperformance.com/install.htm
Look at the underlined paragraph
Old Mar 13, 2002 | 02:15 PM
My Cattman SS pipe hit the frame. I had to grind away a bit to get it to stop. Also, the O2 sensor was in a bad position. I sent him that information and I'm pretty sure they relocated it to a better one after that. There are variations between any 2 vehicles, and the same with parts. Tolerances aren't perfect and sometimes things just don't quite fit right. For instance, I've heard other people besides me have had problems with their PR engine mount fitment. I sent my stock front one to them so they can check their measurements.
Old Mar 13, 2002 | 03:18 PM
TintDaMax's Avatar
Same exact thing happened to me. I didnt know what the hell it was, but it just went away after about 2 days. I have no idea why
DPW
Old Mar 13, 2002 | 03:25 PM
Craig Mack's Avatar
All YOUR grammer belong to me
sup all
A clone of calvin or you just like his username ?
Old Mar 13, 2002 | 04:09 PM
DPW
I've noticed with a few mods that once the ECU gets used to it the car seems more normal. When I added a cone intake it was really loud, but after awhile the car just droned. Same with the PR mounts (though I don't think the ECU has anything to do with those) but the car settles into its new configuration.
Old Mar 13, 2002 | 05:17 PM
skeelo34's Avatar
sounds like another pos cattman ypipe. I'll never stop regretting getting mine!
Old Mar 13, 2002 | 05:20 PM
MAXINXS's Avatar
Sad but true!
Old Mar 13, 2002 | 06:28 PM
Once I got mine fitted right (a few hours extra work) it's been fine and trouble free.
Old Mar 13, 2002 | 08:05 PM
JUDE's Avatar
Are there any fitting problems with the Stillen one? I have heard that they just rust within a year or so.
Old Mar 13, 2002 | 08:46 PM
iregula's Avatar
warspeed or even better...BUDGET.. eh?
Old Mar 13, 2002 | 09:12 PM
klee215's Avatar
thanks for da help guys.......By da way at WOT there is no sound i was downshifting and pushing da max and no banging .. Just when i start off hard and da wheels start to hop alil thats when i hear da loud banging..
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
