How Fast Is This
Old Mar 15, 2002 | 03:46 AM
BrianV's Avatar
How Fast Is This
6300 RPM in 5th gear in a 4th gen?
Old Mar 15, 2002 | 05:25 AM
Confused's Avatar
Permanent Maxima.org Resident
Re: How Fast Is This
You will need another speedo or other means of measuring.... at least on a 96.
Old Mar 15, 2002 | 05:46 AM
mzmtg's Avatar
Minister of Silly Walks
Brian,
Do the math. See what mph you get at 3000rpm in 5th. Then multiply that by 2.1
Easy...
Old Mar 15, 2002 | 05:55 AM
Stereodude's Avatar
Pretty much 150MPH.
Stereodude
Old Mar 15, 2002 | 10:32 AM
d_98SE's Avatar
stock 98 5spd
4th gear @ 6000+rpm=120mph
5th gear @ 5700+rpm=135-140mph
You should be over 140mph that is all i know ask sprint he has 6000+rpm at well over 140mph in a sig of his
Old Mar 15, 2002 | 10:50 AM
Sprint's Avatar
Originally posted by d_98SE
stock 98 5spd
Old Mar 15, 2002 | 12:34 PM
Stereodude's Avatar
I guess no one believes me. The math works out to 150MPH.
Stereodude
Old Mar 15, 2002 | 12:37 PM
Nealoc187's Avatar
SLOW
Also depends on your wheel/tire combo... the indicated speed could be different from your actual speed. If its only 2% off, at those speeds thats a + or - 3mph difference.
Old Mar 15, 2002 | 02:34 PM
2K2THEMAX's Avatar
It's 159 or 160 on stock tires. On 225/45R17's, it's about 169!
Daniel
Old Mar 15, 2002 | 02:48 PM
Stereodude's Avatar
Daniel
I'm certain your math is in error. 225/45-17s would be slower than the stock tires. What are you using for the stock tires for a 4th gen?
Stereodude
Old Mar 15, 2002 | 02:54 PM
Black VQ's Avatar
Stereodude
From a stop, larger wheels and tires only slow acceleration. At top speed, they would slightly increase your gearing, resulting in a higher top speed.
Old Mar 15, 2002 | 03:01 PM
mzmtg's Avatar
The size of the wheels has nothing to do with speedo error. It's the overall diameter of the wheel & tire that makes the difference.
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
