Supercharged Maxima - LONG ROADTRIP
Old Mar 19, 2002 | 07:41 PM
BrianV's Avatar
On my last road trip to San Francisco from Los Angeles I fried my motor as most of you know. I think I may be leaving on a road trip to a much furthur Austin, Texas at the end of the week. I'm very afraid that something similar is going to happen again because last time I wasn't really running the car hard and the temp sensor didn't rise.
I just ordered stage 6 ngk platinum plugs to put in. What else can I do to ensure everything will work perfectly? Do you think a real water temp sensor and an exhaust temp sensor would help?
Old Mar 19, 2002 | 07:42 PM
MardiGrasMax's Avatar
Fuel Pressure and EGT gauges are a must have IMHO
Old Mar 19, 2002 | 08:17 PM
BrianV's Avatar
I was thinking of intake temp sensor
Old Mar 19, 2002 | 08:31 PM
1MAX2NV's Avatar
That's not going to save the motor.
Old Mar 19, 2002 | 10:33 PM
Chebosto's Avatar
RIceD OuT moDErAtor
change the oil to synthetic... if ur going long haul...
use good gas. octane boost it.
drive granny.
Old Mar 19, 2002 | 11:41 PM
BrianV's Avatar
Yeah synthetic is definately in.
I don't agree with the octane booster, boosted octanes raise internal temperatures.
Old Mar 19, 2002 | 11:54 PM
Chunger's Avatar
My other car is a Hybrid
Higher octane should increase combustion temperatures normally... just added insurance against predetonation under load (boost)...
Get an EGT and I'll help you put it in one of these weekends.
Old Mar 20, 2002 | 12:58 AM
BrianV's Avatar
I'm going SOON!!!
Yeah well I plan on staying out of boost the entire time. I've noticed with my normal every-day driving, and sometimes aggressive driving that I rarely if ever go into boost. It takes nearly flooring it for me to boost.
Old Mar 20, 2002 | 05:45 AM
Originally posted by Chebosto
drive granny.
Yup, I drive Paw Paw on the highway! The time you save by speding and being aggresive is just not worth the bling bling. 8mph over thats me
Old Mar 20, 2002 | 05:52 AM
RussMaxManiac
Yea but once he hits those Texas Freeways he can't keep himself from pushing that medal down to the medal!! :P
Old Mar 20, 2002 | 06:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
self control...
some have it
some don't
Old Mar 20, 2002 | 06:52 AM
yongjun's Avatar
You passing through Dallas?
Heheh meet up with the Dallas people
Old Mar 20, 2002 | 07:45 AM
deezo's Avatar
I'm going SOON!!!
Well definitely you have to save the car on a trip like that. What I mean is drive the car easy on the way out. Try not to take it over 75 or maybe even 80. On long trips, I try to be as easy as I can on the motor because of the heat buildup and the run time. I also don't accelerate hard when taking off from toll booths or onramps. Just be easy on her for a few ours and keep checking for unexplained noises and leaks around the SC.
Old Mar 20, 2002 | 08:24 AM
BriGuyMax's Avatar
[hillbilly voice] I wish I was in TexASS [/hillbilly voice]
Old Mar 20, 2002 | 11:15 AM
BrianV's Avatar
What about ~90??
I plan on only driving really at night.
Old Mar 20, 2002 | 04:33 PM
SuDZ's Avatar
Maybe make a stop or two along the way to let it cool down as well. Like just pop the hood (not all the way open but enough to let some extra heat out) while getting a drink or something. It will let it cool down some and make the stress a bit less.
SuDZ
Old Mar 20, 2002 | 06:52 PM
BrianV's Avatar
I'm removing my right fog light so the CAI gets even colder air, and you guys will laugh, but I'm honestly just going to remove my front right headlight as well. THat will force outside air right onto the S/C and part of the intake pipe.
Old Mar 20, 2002 | 07:24 PM
Just take it easy on the trip. I drove from Upstate New York to New Orleans non stop, 22hrs only stopping for gas etc...
Old Mar 20, 2002 | 07:39 PM
BrianV's Avatar
MardisGras were you boosting, what PSI?
I'm actually debating installing a shortram intake right after the MAF and leaving the main SC pipe in the trunk and hooking it back up when I'm in town. I won't push the car so the vaccuum on the FMU shouldn't flood the engine. The S/c will just be blowing air open into the bay not connected to the intake.
Old Mar 20, 2002 | 07:49 PM
No boost at steady cruising speeds. I get vaccum at cruising speed ~70-80mph.
Old Mar 20, 2002 | 08:52 PM
Xtreme5053's Avatar
Let us know when you plan on getting in at austin. I'd love to see your car. : )
Old Mar 20, 2002 | 11:09 PM
BrianV's Avatar
I have no boost like every, but the problem is the supercharger regardless of boost or not makes the intake tempature significantly hotter.
My car is having a misfire problem, I think I blew a coil pack, tomorrow I'll know if I'm going (if I can fix the car)
Old Mar 21, 2002 | 04:55 AM
deezo's Avatar
What about ~90??
Well if your going 90, your RPM's will be around 3g's meaning bad fuel economy.
Old Mar 21, 2002 | 06:07 AM
ejj's Avatar
ejj
90 mph in a 5 speed is closer to 3750 or 4000 RPMS. 3000 RPM's is just over 70 mph.
Old Mar 21, 2002 | 07:44 AM
The other night I hooked up the OBDII lap top thingamajiggy and drove aroung monitoring intake temps, timing and RPM's. I was getting 140f while cruising at 60mph. When I nailed it I got ~130, I was like WTF that aint right! Then I rememberd the water injection, LOL.
Old Mar 21, 2002 | 09:35 AM
Badaxxima's Avatar
Hey MardisGras, what's up with your sig? How'd you get a 44hp and 65lb-ft. power increase, a 3mph trap speed increase and no change whatsoever in your 60' and ET's? WTF? Did you break 'em loose halfway down the track or what?
Old Mar 21, 2002 | 09:50 AM
deezo's Avatar
OOOPS!!!!! I'm thinking in terms of the auto. Sorry!
Old Mar 21, 2002 | 09:53 AM
ejj's Avatar
ejj
You're forgiven ( for making the mistake, not for getting an auto )
Old Mar 21, 2002 | 11:17 AM
the NOS run was my second run, about 1 hour later! I forgot that I had to shift it lower for the nitrous power band, it cuts off at 5600. As far as 60', 2.05 is all those little 205/50-15 BFG gForce DR's has in them. Time for slicks!
Old Mar 21, 2002 | 04:26 PM
BrianV's Avatar
MardisGra what's the cost for the waterinjection setup? I may opt for that over the front mount I/C I was planning
Old Mar 21, 2002 | 08:04 PM
The real deal Aquamist basic system is ~425, Kev has this.
My DIY kit was ~250. http://members.aol.com/raydorman/
Old Mar 21, 2002 | 09:21 PM
eliasmavs99's Avatar
Hey Brian V, I would also like to check out your car, let us know when you'll be in austin and we could chill or something. Peace.
kjlouis
Nov 24, 2018 06:09 AM
JRod28
Feb 4, 2016 11:07 AM
criminalslang810
Aug 16, 2015 08:12 AM
egali045
Aug 5, 2015 09:02 AM
maxima297
Aug 3, 2015 12:50 PM
