Nickel-Plated Rotors...
Old Mar 21, 2002 | 03:55 PM
MaXXX's Avatar
How much of an advantage/disadvantage are these?
Thanks!
MaXXX
Old Mar 21, 2002 | 03:58 PM
Viscous's Avatar
Re: Nickel-Plated Rotors...
Thanks!
MaXXX
The don't rust- so they just look better. Silver rotors vs brown nasty looking rotors. Thats it.
Old Mar 21, 2002 | 04:29 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: Re: Nickel-Plated Rotors...
Well, the "vanes" in the vented disc brakes will tend to hold their structure better since they aren't having a tendency to rust. Theoretically, that translates into longer disc life, ESPECIALLY when you have the rotors "turned".
Unfortunately, I'm only aware of x-drilled/slotted rotors that have a zinc or nickel or cadmium plating. Blank rotors from vendors don't come this way for Maximas. If you have seen Toyotas and Volvos in the past year or two, all of their vehicles are going with such a plating on their stock rotors, probably to maximize longevity to outside of the warranty period. But that is pure speculation.
In addition, it won't be an issue to disassemble your rotor if need be or when you are doing something that requires you to take off your wheel since the hub won't rust itself to the back of your wheel.
The Wizard
Aug 4, 2010 05:55 PM
Audio/Video/Electronics
May 22, 2009 08:23 PM
wyche89
Mar 13, 2007 11:30 PM
koostermax
18
Oct 19, 2003 02:20 AM
Eric
Aug 24, 2002 10:36 AM
