simple wheel bearing question
Old Apr 2, 2002 | 12:06 PM
medic's Avatar
Had the car in for an alignment and the mechnic said the rear wheel bearing needed to be replaced.
1) Other then getting a second opinion, wow do I tell if he's saying the truth or blowing smoke up my a**
2) The car is running fine. If I don't get fixed, what's the downside?
Old Apr 2, 2002 | 12:18 PM
NightRider's Avatar
Re: simple wheel bearing question
Mine needs to be replaced too. Drive on it for a little while. If you hear a groaning noise when you're idling (with your foot off the brake) or moving slow, they are grinding. If you don't replace them, your rear alignment will mess up.
Old Apr 2, 2002 | 12:46 PM
medic's Avatar
okay, so alighnment but no permanent/more expensive damage. The mechinc said if I didn't do it crap would get in that area and corode the entire assembly.
I have a deal where I can get my alignment done as often as I want for free so that's not a big deal.
Old Apr 2, 2002 | 01:12 PM
NightRider's Avatar
Well don't take my word for it because that was all I was told by another member. Your mechanic may be right in this case. I would take it to get a second opinion or ask some local mechanics what they think. I'm no expert at it.
Old Apr 2, 2002 | 01:29 PM
DanNY's Avatar
Ad·min·is·tra·tor
1. check for play in the rear wheel. it's almost like a bad ball joint/tie rod. get the rear wheels in the air and try to move the wheel...if there's play in the wheel then the bearings are going/gone.
2. if you don't get it fixed your tires will wear out in some abnormal pattern. you'll also hear more noise from the bearings wearing out.
Old Apr 2, 2002 | 02:29 PM
SuDZ's Avatar
The alognment may be free but replaces the tires from abnormal wear is not going to be covered. May be cheaper just doing it now than waiting and buying new tires and then having it done anyhow.
SuDZ
boomerbrian
Nov 8, 2015 05:10 PM
seesole
Aug 26, 2015 11:22 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
