14.0@102mph WTF?!?!
Old Apr 10, 2002 | 11:47 PM
BriGuyMax's Avatar
14.0@102mph WTF?!?!
ok...little disclaimer here...so I don't get flamed....the track conditions were total cr@p tonight....I usually pull very consistant 2.2-2.25 60' times....tonight my BEST 60' time was 2.4...
anyway...to the good stuff....I took my 100-shot to the track for the first time....previous best was 14.0@99 with a 50-shot and a 2.24 60'
handicaps....I was running my STOCK y-pipe tonight becuase my cattman y-pipe has the infamous "broken flex"....rendering it completely useless...so my car has NO TOP END....I also haven't tuned my 100-shot...so it's running REALLY rich....and to top it all off....I'm running stock suspension
my BEST of three runs tonight was 14.0 (DAMMIT!!!!!) @102 with a 2.4 60'
I like the 102mph trap....but the 14.0 with a 100-shot just won't do....plus my 1/8 time was 9.2 whereas my 1/8 miles BEFORE with only my 50-shot were 9.0.....that means there was spinning going on AFTER the first 60'.....and I WASN'T spraying out of the hole....I didn't turn the juice on until second gear.....
oh well...maybe next time I will FINALLY hit 13s.....
Old Apr 11, 2002 | 12:04 AM
Nealoc187's Avatar
SLOW
Maybe your car is physically incapable of running 13s. You've run 14.0 on 3 different shots now on 3 different occasions.
Old Apr 11, 2002 | 12:12 AM
Maximus1000's Avatar
If I can perfect my launch, I'm pretty sure I can get a 14 flat out of my stock 2K2 6 speed. Look at my 99mph trap speed, that should be 14 flat.
Old Apr 11, 2002 | 12:14 AM
BriGuyMax's Avatar
nah..the first two times were with the 50-shot....but it is true that it was on three different Occasions...every sucessive occasion my trap speed gets HIGHER....first was 14.0@97...then 14.0@99....NOW 14.0@102
I'm cursed
Old Apr 11, 2002 | 12:15 AM
BriGuyMax's Avatar
yea...and I would be running 13.5 or BETTER with a perfect launch
Old Apr 11, 2002 | 12:40 AM
Practice makes perfect. I intend to practice.....lol
Old Apr 11, 2002 | 01:21 AM
black019's Avatar
your car = devil
Old Apr 11, 2002 | 01:32 AM
20th maxstyle's Avatar
better luck next time slow poke. Maybe if you would have let me know you were going, I would have made it up there with you to give you a push start. Later Mr. wah wah 14's while the rest of the world is at 15s. Well you can kiss my rear AE end. Oh by the way, is the meet on the 20th at Uno's in schaumburg, or somewhere else.
Old Apr 11, 2002 | 04:23 AM
Jime's Avatar
BriGuy how high is your fuel pressure for your 100 shot?
Old Apr 11, 2002 | 05:24 AM
SteveChicagoSC's Avatar
Looks like you need some rubber!!! Are you racing on Saturday?
Old Apr 11, 2002 | 06:51 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
it's all in the 60ft...it just looks like you've got no traction...traction = better 60fts = more accurate time for you in relation to your trap speed
Old Apr 11, 2002 | 07:03 AM
JAIMECBR900's Avatar
I was wondering that too, and what jet combo are you using (if it's NOS) to get the 100 shot. I just called the NOS tech line yesterday and you would of thought I was cussing the guys mother out or running the N2O in his car. He said it was not possible to run a 100 in a max because it would blow the engine since there is no way to NOT run lean eventhough I explained to him I have a Walbro 255 pump and going to install an aftermarket FPR BEFORE I attempt the 100 shot. Can you help, that guy just refused to tell me the combo. Thanks.
Old Apr 11, 2002 | 07:27 AM
MardiGrasMax's Avatar
Yup, and with a 110mph trap I should be mid 12's.
It is what it is!
I feel your pain.
Get some slicks.
Old Apr 11, 2002 | 07:51 AM
BriGuyMax's Avatar
well...the completely horrible traction last night was due to track conditions...even guys with slicks were complaining about hooking up....I could usually pull a 2.2 60ft which would have put me well into the 13s....
Old Apr 11, 2002 | 08:56 AM
Sprint's Avatar
.069 to .071 fuel jet.. it varies.. you have to watch your fuel pressure gauge and keep going higher jets till your fuel pressure drops down.. each car will be different
Old Apr 11, 2002 | 11:04 AM
MAX2000JP's Avatar
HaHa..14.0 isnt nothing to be ashamed of. You should dyno tune your NOS to make sure its running at maximum effeciency.
Old Apr 11, 2002 | 11:15 AM
HondaKiller718's Avatar
Man if you tune your Nawws you will be running 9's
Old Apr 11, 2002 | 11:39 AM
CHI99Limited's Avatar
Traction did suck last night Brian, i was so mad i only got to run once. I didnt want to leave there with a best of 15.77@90mph. My 60' time was terrible also, i managed a 2.6. Im gonna go to RT66 one day soon if you care to join me, hopefully there track is up to par.
Old Apr 11, 2002 | 12:30 PM
BriGuyMax's Avatar
Definitely dude....last spring when I went there I had NO IDEA how to launch my car...and I was pulling 2.2 60ft's all day long....that track has SOOOO much grip....
Old Apr 11, 2002 | 02:01 PM
MAX2000JP's Avatar
Seems like everytime you go to GL Dragaway, you have traction problems Brian. Take it to Rt.66 and see what you can do You saw how well my car hooked up last summer. My whole exhaust system looked like it was gonna touch the ground You get more runs and Rt.66 is much nicer. The only advantage to Great Lakes is the abundance of rice.
Adam needs to work on those 60' times, 2.6 is pretty bad. Ive seen quite a few autos pull 2.2-2.3 60's. If Adam were to pull that he would be right around 15.1-15.2. I am sure he will gain 1 mph with the UDP he is getting.
Correct me if im wrong....... .1 off the 60' equates to .2 off your 1/4 time???
Old Apr 11, 2002 | 06:18 PM
BriGuyMax's Avatar
yes...roughly....
Old Apr 11, 2002 | 06:24 PM
OriginalMadMax's Avatar
I'm cursed
You need LSD! Maybe the disk type for $299 that was posted here yesterday, if you can't afford the Quaife.
Old Apr 11, 2002 | 09:19 PM
MAX2000JP's Avatar
Not needed!!
Old Apr 11, 2002 | 09:55 PM
You must be talking about a wet system. I have a dry set up in my car. If not, are you saying a .069 to .071 main jet?
Old Apr 11, 2002 | 11:24 PM
BriGuyMax's Avatar
I already have the quaife bud
Old Apr 12, 2002 | 06:44 AM
Cumalot's Avatar
Something definitely isn't right. IIRC, Synki also ran a 14.0 with a 100 shot of NOS. However, he's an automatic. Plus, I think he could have done better if he had better traction. So a 5spd Maxima with a 100 shot of NOS should be even faster.
Old Apr 12, 2002 | 10:28 AM
mtrai760's Avatar
'Trynna' is not a word
.047 NOS, and fuel will vary on your car, but you want to run around 85 psi... usually between a .055 and .073
Old Apr 12, 2002 | 12:03 PM
Synki's Avatar
Yep.
Welcome to the club of not hitting 13's.
I ran 100+ mph trap speeds in my auto w/ 2.3 60fts.
I know traction was a HUGE issure for me when i dragged my Max, plus it would have been nice if i had a catback and a few other mods at the time.
Old Apr 12, 2002 | 03:50 PM
Sprint's Avatar
nope.. i have a dry setup witha .69 jet.
Old Apr 13, 2002 | 02:15 AM
BriGuyMax's Avatar
but I ran 14.0 with a stock y-pipe, un-tuned NOS, a HORRIBLE 60ft and a slower 1/8 mile that when I had my 50-shot and ran 14.0...that's got to tell you something...
Old Apr 13, 2002 | 10:49 AM
Cumalot's Avatar
Yeah, exactly my point. You should be well into the 13s with the 100 shot.
Maybe you should go back to NA and sell me your NOS kit. j/k
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
